My work is based in Engineering for naval ship maintenance. We have just completed a half-life refit for one particular vessel which has involved big changes to equipment positioning and system modifications in the Engine Room areas. It has been decided as a first time, to use a laser scan to create a 3D model of the areas affected. This will provide us with the updated details from which we can create 2D drawings and various views. This move into a laser scan is considered as the best option as the task of trying to update the existing "As-Built" design drawings is not practical and too expensive to implement.
Has anyone had experience of this procedure in their work and do you consider ReCap as a recommended file viewer with this process, as we have to make the scanned model available to several departments.
Your advice and suggestions will be appreciated.
Stay Safe
Niall
Solved by warrenf. Go to Solution.
I use Recap on industrial projects and all my clients are really impressed with its ability to aid in the creation of very accurate 2D or 3D drawings/models. I would suggest a professional do the scan so that they can get you the level of detail you'll need on such a critical project.
Hi warrenf,
Do you know of any free viewer that can be recommended to colleagues, if someone just needs to open a laser scan model to view and reference.
Regards
Niall
