Indexing e57 problem
jared.white
jared.white
I have a 16GB e57 file that i am trying to index in the latest version of recap (recap360_30052).  We have older versions of recap that work correctly, and don't have any issues with the same file, but they don't have mirror balls either, which forces us to still create Leica TruViews for customers.  the e57 was generated from cyclone.  In the images below you can see that one of the locations is missing a lot of data.  I've also attached the image of the realview from that scan.  I can't explain what it is doing.  Its putting the ground data in the form of trees... I have no explanation.... undefined
undefined
Replies (13)
ashwini.murthy
Strange. Would you mind sharing one or two scans to help us recreate the issue? I will send you a PM with details to a shared box folder.
The latest version of Recap as of today is 3.0.1.5. I strongly suggest updating.
Ashwini
jared.white
i downloaded the latest version from your website this morning...  Is this the right page?  It does not match the version you mentioned.
http://www.autodesk.com/products/recap-360/free-trial
ashwini.murthy
The one you downloaded is 3.0.0.52, and that is the same as what you already have.
The latest version 3.0.1.5 is an update and is available here https://knowledge.autodesk.com/support/recap/downloads/caas/downloads/content/important-update-for-a...
Other way to find if an update is available is to look for a "Update available" notification when you open Recap.
-Ashwini
jared.white
After updating, it is still giving me the same issues..  I'm compressing an e57 file no share with you now.
undefined
ashwini.murthy
Sorry, it didn't work out 😞 and thanks for sharing the file. I will try to recreate on our end and send it over to the engineering team.
Ashwini
jared.white
I tried uploading the file, but it must have stopped at some point.  Instead I've uploaded a different e57 file of a different job.  The same issue is presnet for all e57 files that we try to index.
ashwini.murthy
Thanks for sharing a sample. I was able to recreate the issue.
But, I have good news! We have already identified and fixed this problem as part of the next hotfix (which will be out very soon!)
Look out for an update when the hotfix becomes available.
Ashwini
jared.white
Great! Do you have a projected release date?
ashwini.murthy
Sorry, I do not have that information.
Ashwini
ashwini.murthy
It released today!
Here are the release notes and update instructions - http://forums.autodesk.com/t5/recap-360-general-discussion/autodesk-recap-360-autodesk-recap-360-pro...
Thanks!
jared.white
Thanks for sending the update! It did correct the data dropping off, but now the realviews will not work at all, and gives the attached message.
jared.white
After restarting the program, everything works great!  Thanks for you help and quick responce!
ashwini.murthy
Excellent!
Type a product name
