One moment also:
I don't wrote about them in previous message - after one cration model from ptotos you can edit it (clear form noises in the photo) and export again as PTS file [it file you can than import to ReCap Pro] and next work as classic RCP project. For transform data from prhoto to Point Cloud you will no lose cloud credits - these operations continued with computer's resourses.
Screen above - when export PTS file form ReCap Photo
Import file to ReCap Pro and indexing it
Delete the remaining noises with cut-rectangle, save model and export again to Civil 3D as RCP file.
Process of creation surface can continue longer - I advice you reduce points in surface in dialog box of ReCap during create surface, because you will got MMS-surface (large and often-fatal file) otherwise.
F.e. below screen of file if I don't select reducing points - you will can't work with that file!
There are 9 570 495 points there!
Biu if I select that scenario (screen below) I will have only 415 512 point
Best regards,
Egor Grebenyuk,
JSC "Roszheldorproject", BIM specialist (infrastructure)
