Existing photo projects stuck in queue?
spear_kevin_pe
Advisor Advisor
Message 1 of 9
spear_kevin_pe
Hi, is there a health dashboard for recap processing? A have several projects that were resubmitted and have been in queue for many hours. Also, many of my project are not showing previews even though the projects have been processed initially through 3DR SiteScan's processes.
Kevin
Kevin Spear, PE
Replies (8)
Message 2 of 9
vidanom
Hi Kevin,
I'll check with the web team and we should get back to you shortly.
Sometimes it can take a little time for projects to start computing.
Mitko
Message 3 of 9
any problems there ?
in queue for a bit, worried i will get an error message after waiting for them to begin processing.
BECAUSE.
for all 3 that are in queue, i got the    RETRY message after 99%.
i hit the RETRY several times, for all 3.  and then refreshed browser after each one
and found   they were in queue,   about an hour or two now,  in queue w no processing happening.
is there a chance browser reads "in queue" even if the project is in error ?
thank you
Message 4 of 9
if it helps, all the images came off of  the a360 drive.   i usually just upload from desktop.
Message 5 of 9
hey folks that 12 hours.
tried another one 1.5 hours ago.
and another with upload not A360.
whats going on ???
Message 6 of 9
stuck in queue 12 hours
whats going on ??
Message 7 of 9
getting
project failed
there was a problem with submission
ER0108
for a few hundred photos..
from A360 drive.
but then goes in queue. after 99%. error. cancel retry.
just tried 20. instead of a few hundred.
no error. and in queue.
Message 8 of 9
vidanom
Hi @Anonymous,
The processing times will depend on how much images are being submitted.
For the error that is happening after 99% it turns out that's due to passed amount of the allowed image count and our service not blocking the projects before they are submitted.
For example if you are using draft mode there should not be more than 50 images submitted, and for ultra mode not more than 250.
The team is working on this case so projects are not submitted with more photos than the allowed.
Mitko
Message 9 of 9
got it.  figured it out via "help" but it didn't say 50 for draft.
