ReCap Forum
Welcome to Autodesk’s ReCap Forums. Share your knowledge, ask questions, and explore popular ReCap topics.
Decap Errors
0 REPLIES 0
Message 1 of 1
andrew_dunn2
336 Views, 0 Replies
Decap Errors
I have had problems getting Decap to work (see post under Decap processing fails), and as part of my debugging efforts I had a colleague process the same files I had for testing. He does get a sucessful rcp file produced, but along the way he gets these error messages:
[P][1 9]
[P][1 9]
boost::filesystem::file_size: The system cannot find the path specified: "K:\_01 Workshop Projects\30040 - Luggage Point Control Room\[Inbound]\[Scans]\.\temp\{d6f073f5_5cc0_40db_aa9c_667818900fe1}\.\temp\{d6f073f5_5cc0_40db_aa9c_667818900fe1}\lp-001_inter7_00.temp05"
boost::filesystem::file_size: The system cannot find the path specified: "K:\_01 Workshop Projects\30040 - Luggage Point Control Room\[Inbound]\[Scans]\.\temp\{d6f073f5_5cc0_40db_aa9c_667818900fe1}\.\temp\{d6f073f5_5cc0_40db_aa9c_667818900fe1}\lp-001_inter7_01.temp05"
boost::filesystem::file_size: The system cannot find the path specified: "K:\_01 Workshop Projects\30040 - Luggage Point Control Room\[Inbound]\[Scans]\.\temp\{d6f073f5_5cc0_40db_aa9c_667818900fe1}\.\temp\{d6f073f5_5cc0_40db_aa9c_667818900fe1}\lp-001_inter7_02.temp05"
boost::filesystem::file_size: The system cannot find the path specified: "K:\_01 Workshop Projects\30040 - Luggage Point Control Room\[Inbound]\[Scans]\.\temp\{d6f073f5_5cc0_40db_aa9c_667818900fe1}\.\temp\{d6f073f5_5cc0_40db_aa9c_667818900fe1}\lp-001_inter7_03.temp05"
boost::filesystem::file_size: The system cannot find the path specified: "K:\_01 Workshop Projects\30040 - Luggage Point Control Room\[Inbound]\[Scans]\.\temp\{d6f073f5_5cc0_40db_aa9c_667818900fe1}\.\temp\{d6f073f5_5cc0_40db_aa9c_667818900fe1}\lp-001_inter7_04.temp05"
boost::filesystem::file_size: The system cannot find the path specified: "K:\_01 Workshop Projects\30040 - Luggage Point Control Room\[Inbound]\[Scans]\.\temp\{d6f073f5_5cc0_40db_aa9c_667818900fe1}\.\temp\{d6f073f5_5cc0_40db_aa9c_667818900fe1}\lp-001_inter7_05.temp05"
boost::filesystem::file_size: The system cannot find the path specified: "K:\_01 Workshop Projects\30040 - Luggage Point Control Room\[Inbound]\[Scans]\.\temp\{d6f073f5_5cc0_40db_aa9c_667818900fe1}\.\temp\{d6f073f5_5cc0_40db_aa9c_667818900fe1}\temp.fws"
[P][1 9]
[P][1 9]
Can anyone shed any light on this error and why it does not seem to affect the output?
We have also seen this error:
Initializing Licensing. Please wait...
[libprotobuf ERROR D:\tmp\protobuf-3.2.0\src\google\protobuf\wire_format_lite.cc:621] String field 'sdk.Sdk2Service.Authorize.feature_id' contains invalid UTF-8 data when serializing a protocol buffer. Use the 'bytes' type if you intend to send raw bytes.
Importing 1 scans to D:\Decap\Test\Project
[F][lp-010.fls][1]
[P][1 1]
Once again this does not seem to affect the output...
I cant find any documentation or information on these errors.. makes it difficult to get Decap to work..
Cheers,
Andrew
Tags (3)
0 REPLIES 0
Rail Community
