Convert RCM to RCP
Convert RCM to RCP
nicolasmenu
Message 1 of 13
Convert RCM to RCP
nicolasmenu
Hi
Any idea How can we convert RCM to RCP and RCP to RCM ?
Is there a converter out there ?
Thanks & Best regards,
Nicolas M.
Replies (12)
Message 2 of 13
vikas.vaishnav
Hello @nicolasmenu
Thanks for writing to us. I am not aware of any convertor for RCM to RCP files. However to have rcm files integrated in to your rcp files you can user Recap Photo to export .rcs and import these while creating recap project in Recap. Please find more details on this post that may help you.
Vikas.V
User Experience, Autodesk Recap
Link Name | Link Name | Link Name | Link Name
Message 3 of 13
anil_mistry
Autodesk Support
Autodesk Support
Hi @nicolasmenu,
I'm just checking in to see if you need more help with this. Did the suggestion that @vikas.vaishnav provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Anil Mistry
Technical Support Specialist
Message 4 of 13
murali.p
Hi Nicolas,
Currently there is no RCM to RCP export in ReCap Photo, but we are working on it and will be available early next year.
Meanwhile you can use PTS export functionality and import PTS in ReCap Pro.
Murali
Message 5 of 13
nicolasmenu
Hi Murali,
Thanks for your answer, this is what I am actually doing. PTS is the only option I could find that would help. Not perfect, but OK for now.
As long as you guys are working on the converter 😉
I would actually like to ask... why no option to export to LAS. Recap photo does a dense point cloud behaind the scene, so why is there no option to save to a standard point clouds file format. .LAS is by far what is most standard anywhere. It is key to be able to input/output LAS even if internaly Autodesk choose to use his own .rcs .rcp or .rcm
Thanks for your time !
Cheers, Nicolas
Message 6 of 13
nicolasmenu
@vikas.vaishnav... The post you mentionned date back from 2014 and as far as Recap Photo is concerned, pretty much everything has changed since then. Not very helpfull at this time (actually this post should be manually removed from the forums as it mostly add information not true anymore).
Murali came up with what I was doing already,. PTS as the exchange file format. No great, but it sort of do the job...
Thanks for your time and have a nice day. Cheers
Nicolas
Message 7 of 13
anil_mistry
Autodesk Support
Autodesk Support
Hi @nicolasmenu,
Thank you for your reply. Sorry, I should have caught that too. But anyway I'm just checking in to see if you need more help with this. Did the suggestion that @murali.p provided work for you?
Anil Mistry
Message 8 of 13
nicolasmenu
@anil_mistry, Yes it does, but I am just waiting to have his thoughts on the LAS format and why there is no export to this as it is the most commonly used format for point  clouds all  over and we can't export to it.. (will tag as solution once this discussion is over) Cheers, Nicolas
Message 9 of 13
anil_mistry
Autodesk Support
Autodesk Support
Hi @nicolasmenu,
Thank you for your reply. This may be candidate for enhancement request. If you have any feedback that you would like to submit regarding any enhancement, please click on the “ReCap IdeaStation” link on the ReCap community home page.  This will help the Project Manager and developers hear your voice on any changes/concerns with functionality directly for consideration in future builds.
Thank you and have a great day!
Anil Mistry
Message 10 of 13
murali.p
Hi Nicolas,
We will evaluate and consider adding LAS export.
Currently, you can use ReCap Pro to export to LAS.
Murali
Message 11 of 13
anil_mistry
Autodesk Support
Autodesk Support
Hi @nicolasmenu,
I am checking back to see if one of the great posts in this thread helped you with your question. If so, please take a moment to reward the poster or posters with a Kudos and select the Accept as Solution button on those posts that helped.
Anil Mistry
Message 12 of 13
nicolasmenu
@murali.p ... That would be good... but there is no export to LAS from Recap Pro (nor Recap Photo) actually... This is what puzzle me !
Only .PTS and .E57
LAS is by far most common...Please export to LAS from Recap  Pro as well 🙂
Workaround us to use Lastools to go from PTS or E57 to LAS. Not very straight forward though...
Cheers, Nicolas
Message 13 of 13
murali.p
Ah yes - sorry my mistake. We will look into exporting to LAS format.
Murali
