Message 1 of 15
Autodesk ReCap Pro 7.0.1.22 - Release Notes
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Autodesk ReCap Pro version 7.0.1.22 has been released
What is included?
Improvements:
- Added the ability to import Leica *.proj files.
- Added the ability to import *.rcc files with DeCap.exe.
- Supported high resolution structured scan.
Fixed Issues:
- Fixed an issue that could occur when suspending and resuming scan indexing.
- Fixed issue where the RealView quality of some scans is downgraded.
- Fixed a stability issue that occured during manual and automatic registration.
- Fixed an issue in which spherical target extraction did not work.
- Fixed an issue in which RangeClipping was not enabled for Leica P16 and Structured E57 files.
- Fixed an issue in which deleted points would reappear after saving and optimizing the project.
- Fixed an issue that could occur when indexing a suspended project with DeCap.exe.
- Fixed an issue in which the overview map was empty after importing scans through DeCap.exe.
- Fixed a stability issue that could occur when exporting a RCS point cloud to E57 format using complete export.
- Fixed a stability issue that could occur when switching scan.
- Fixed a stability issue that could occur during project optimization.
- Fixed an issue in which coordinate transformation did not work when importing an ASCII file.
- Fixed an issue that could occur when importing an ASCII file with a non-numerical index.
- Fixed an issue that could occur when importing custom E57 files.
- Fixed an issue in which files could not be saved if a username contained a Unicode character.
- Fixed an issue in which suspend registered scan cannot return back to registration view.
- Improved SHIFT dragging interaction with the limit box.
- Improved Auto Registration UI.
Installation Instructions
You must have administrative privileges on your Microsoft® Windows® operating system to complete the installation process.
a. Using Autodesk Desktop App:
- Ensure Autodesk ReCap version 7.0.0.183 is installed on the computer.
- Launch Autodesk Desktop App from the system tray or from Start -> Autodesk -> Autodesk Desktop App.
- Click on the 'Updates' tab; ReCap Pro 2021.1 Hotfix should be visible in the list.
- Click on 'Install'. The new update will be downloaded and installed. Autodesk ReCap current version 7.0.0.183 will be updated to version 7.0.1.22.
b. Direct download & install:
- Login to Autodesk Account: https://manage.autodesk.com/home/
- Download ReCap Pro update from "Product Updates"
- Double click on ReCap_Pro_v7.0.0.183_to_v7.0.1.22.msp
- Follow the installation instructions on the screen. ReCap / Pro's current version 7.0.0.183 will be updated to version 7.0.1.22.
Prerequisite:
- Please ensure Microsoft Visual C++ 2010 Redistributable (x64) and (x86) are installed in your PC in order to be able to import Leica *.prj file.
Klarinda Gunadi Widjanarko
Senior Software Engineer
