Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
ReCap Forum
Welcome to Autodesk’s ReCap Forums. Share your knowledge, ask questions, and explore popular ReCap topics.
"1 Files will be ignored. These files may exist in the project or have duplicate output file name"
4 REPLIES 4
387 Views, 4 Replies
Hello to all. I have a problem that has already happened to me a couple of times .... When I try to put together 2 point clouds with different scans of the same project I get this message:
This happens after opening a point cloud I try to import another one. Clouds don't have scans of the same name!
Any suggestions?
4 REPLIES 4
yan.fu
Duplicate .rcs files are not allowed in the same project. Could you try to rename the .rcs file and then re-import into your project?
in reply to: yan.fu
Thanks for the quick answer.
Maybe I haven't made myself clear. I work with a big project, every day I make new scans (Focus3D 330x).
To control the scans, I create a new cloud and then assemble them if satisfied.
All fls files have different names, so I don't even have rcs with the same name.
Finally, all the clouds are imported into the main project.
other tips?
adekker22NLF
I have the same issue. Trying to merge 2 scans with polar opposite names but still gives the error that the output name is the same. Any advise on this?
Hi @adekker22NLF
Have you tried the solutions in this article?
https://knowledge.autodesk.com/support/recap/troubleshooting/caas/sfdcarticles/sfdcarticles/Unable-t...
Maksim Melnikov LinkedIn | Instagram
Autodesk Solutions Expert
Autodesk Certified Instructor
Rail Community
