Hello to all. I have a problem that has already happened to me a couple of times .... When I try to put together 2 point clouds with different scans of the same project I get this message:
"1 Files will be ignored. These files may exist in the project or have duplicate output file name"
This happens after opening a point cloud I try to import another one. Clouds don't have scans of the same name!
Any suggestions?
Thanks for the quick answer.
Maybe I haven't made myself clear. I work with a big project, every day I make new scans (Focus3D 330x).
To control the scans, I create a new cloud and then assemble them if satisfied.
All fls files have different names, so I don't even have rcs with the same name.
Finally, all the clouds are imported into the main project.
other tips?
I have the same issue. Trying to merge 2 scans with polar opposite names but still gives the error that the output name is the same. Any advise on this?
Hi @adekker22NLF
Have you tried the solutions in this article?
https://knowledge.autodesk.com/support/recap/troubleshooting/caas/sfdcarticles/sfdcarticles/Unable-t...
