Previous Version Support
Welcome to Autodesk’s Previous Version Support Forums. Share your knowledge, ask questions, and explore Previous Version Support topics.
Install Autocad 2010 32bit on Windows 7 64bit
4 REPLIES 4
6192 Views, 4 Replies
Hi, I need to know if you can install Autocad 2010 32bit on Windows 7 64bit.
Thank you
Tags (1)
4 REPLIES 4
Alfred.NESWADBA
it's not supported by Autodesk (except of Civil 3D 2010 as this is only available for 32bit).
The chance you have is >>>longbow converter<<<
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
in reply to: Alfred.NESWADBA
autocad 2010 on windows 7b 64 bit
pendean
Autodesk ended automatic reauthorizing of 2010 and older software as of August 31 2019, read all about it here https://knowledge.autodesk.com/support/autocad/learn-explore/caas/simplecontent/content/previous-ver...
Sorry, you missed the deadline.
Administrator Productivity
