Hi, I need to know if you can install Autocad 2010 32bit on Windows 7 64bit.
Thank you
Solved by Alfred.NESWADBA. Go to Solution.
it's not supported by Autodesk (except of Civil 3D 2010 as this is only available for 32bit).
The chance you have is >>>longbow converter<<<
- alfred -
Autodesk ended automatic reauthorizing of 2010 and older software as of August 31 2019, read all about it here https://knowledge.autodesk.com/support/autocad/learn-explore/caas/simplecontent/content/previous-ver...
Sorry, you missed the deadline.
