i have Autocad LT 2011 but i lost the CD of the version 64 bits, how can download this program.
Thanks.
Marcelo Rodríguez
marcelo.rodriguez@gruppoat.com
Solved by muriel.a. Go to Solution.
Hi @Anonymous and welcome to the Autodesk Community!
I will open a support case and will send you the download links directly via e-mail.
Same problem for me, I can't find a working link to download autocad 2011.
Could you please help me?
Antony H
@Anonymous
Welcome to the Autodesk User's Community..
This is a 7yr old product and no longer supported by Autodesk. There's no live download link for it.
Where did you get this version from? Or why you need this version?
Mark Lancaster
& Autodesk Services MarketPlace Provider
Hi and thx for your answer,
We baught this product several years ago and still use it.
We have a licence and would like to reinstall it after a format of our computer.
The cd installation we had when we baught it is not windows7 compatible but in 2014 the support gave us a link to download a good version.
The customer support just sent me a link for the 32 & 64bit versions.
Best regards
I just noticed this thread. I am also in the same boat with regards to ACADE 2011 and Win 7 64-bit. I have a copy of the 32-bit from back in the day. Can I also get a link for the 64-bit download?
Thank you
Doug
Hi @dmray
Autodesk supports products up to three versions past the current release. For versions older than 3 versions back, please contact our Customer Support to request the download links (select Chat or Email). Please note that any unsupported versions can become unavailable at any time.
Another option:
https://knowledge.autodesk.com/contact-support/websupport/finding-download
Hi there
I too need the 64bit 2011 download. I've tried contacting customer support but have not had a response yet.
Could you help please.
I have all relevant codes & keys.
Jo
@Anonymous Good luck as previously said there is no live download.
If you're lucky https://knowledge.autodesk.com/contact-support/installation-activation might respond
But otherwise unless someone here has the files it's the end of the road.
Autodesk sent me a download just over a month ago but it took me longer to find a laptop than i thought it would. The download subsequently timed out after 30 days. I'm hopeful they can help again.
Thanks though.
@Anonymous
What OS are you trying to install it on:
Download Autocad 2011 64 bits
Also, after March 2021 you won't be able to license it anymore and will have to upgrade
Can I activate a perpetual product version 2011 and later?
Yes. Product activation for versions 2011 and later is available until March 2021, when product activation aligns with the Lifecycle policy.
Hi @Marian-IT,
The last post before you was in 2019 - so this is quite an old post, the main issue is that you won't be able to activate since March 2021 Autodesk has ceased activation of 2011 Products and Older.
hello,
I have also bought an autocad 2011 cd but as you can imagine, I haven't had a pc with cd player for years.
can you please send a download link? It would be a great help!
thanks in advance!
2011 is not available anymore like what said already Autodesk ended activation for 2011
DarrenP
