Have used AutoCAD Map 2000i since 2000 without major problems. Yesterday tried entering a dwg file, got the following error message: Runtime Error!
Program: C:\Program Files (X85)\AutoCAD Map 2000i\acad.exe
abnormal program termination. Tried to reinstall using the AutoDesk provided DVD; would not install. Help, please
[ The subject line of this post has been edited for clarity by @pendean Original: Runtime Error!]
@johnusma57 you and everyone else at some point sadly have these issues (Win10 was released in 2015, so that's not true either).
MAP2000i's system requirements do not include Win10, so Autodesk is never going to offer tips or solutions for it
These folks offer lots of tips (and if needed as a last resort, a product to buy to fix the issue), start exploring and testing and implementing https://longbowsoftware.com/home
Good luck.
no Autocad 2000i came out over 20 years
it was not made to run on newer OS & never will be made compatible
you can try running in compatible mode but no guarantee this will work:
DarrenP
could have been a windows update that broke it which is known to happen
DarrenP
Uninstall Map 2000i and then try these steps using longbow - their solution solved my specific issues every time
