Previous Version Support
Welcome to Autodesk’s Previous Version Support Forums. Share your knowledge, ask questions, and explore Previous Version Support topics.
AutoCAD Map 2000i Runtime Error!
11 REPLIES 11
Message 1 of 12
johnusma57
1077 Views, 11 Replies
Have used AutoCAD Map 2000i since 2000 without major problems.  Yesterday tried entering a dwg file, got the following error message: Runtime Error!
Program: C:\Program Files (X85)\AutoCAD Map 2000i\acad.exe
abnormal program termination.     Tried to reinstall using the AutoDesk provided DVD; would not install.  Help, please
[ The subject line of this post has been edited for clarity by @pendean Original: Runtime Error!]
Tags (1)
11 REPLIES 11
Message 2 of 12
Simon_Weel
in reply to: johnusma57
Can you try a repair instead of reinstalling?
Message 3 of 12
johnusma57
in reply to: Simon_Weel
Tried a Repair, got the same Fatal Error message.
Message 4 of 12
pendean
@johnusma57 What's your Windows version my friend? Wrong answers would be Win10 and Win11.
Message 5 of 12
johnusma57
in reply to: pendean
Windows 10; I have been running this version of AutoCAD Map 2000i on the
same OS and same computer since 2000; why suddenly won't work?
Message 6 of 12
pendean
@johnusma57 you and everyone else at some point sadly have these issues (Win10 was released in 2015, so that's not true either).
MAP2000i's system requirements do not include Win10, so Autodesk is never going to offer tips or solutions for it
These folks offer lots of tips (and if needed as a last resort, a product to buy to fix the issue), start exploring and testing and implementing https://longbowsoftware.com/home
Good luck.
Message 7 of 12
johnusma57
Yes, did not mean to imply I had used Windows 10 since 2000, sorry. Meant
I have used the AutoCAD with Windows, multi versions, since 2000. First I
have heard that AutoCAD has issues with Windows 10; is there no way to fix
the problem? I am now retired and can't see my way to spend the kind of
money needed for new version of the software.
Message 8 of 12
DarrenP
no Autocad 2000i came out over 20 years
it was not made to run on newer OS & never will be made compatible
you can try running in compatible mode but no guarantee this will work:
https://support.microsoft.com/en-us/windows/make-older-apps-or-programs-compatible-with-windows-783d...
DarrenP
Message 9 of 12
johnusma57
in reply to: DarrenP
Was running well for many years on Windows 10; what happened; was there an
"Adobe" disabling?
Message 10 of 12
DarrenP
could have been a windows update that broke it which is known to happen
DarrenP
Message 11 of 12
johnusma57
That makes sense; thank you. Started using AutoCAD in 1982; I am now
retired, so I can do without it. Will miss tinkering on it though. Thanks
again for your help.
Message 12 of 12
tomhurns
Uninstall Map 2000i and then try these steps using longbow - their solution solved my specific issues every time
Administrator Productivity
