Activation does not succeed for AutoCAD LT 2008.
Check these links for as additional resource:
https://forums.autodesk.com/t5/installation-licensing/bd-p/24
https://forums.autodesk.com/t5/autocad-lt/ct-p/2000
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Try to offline method but not received the activation code.
Autodesk stopped generating activation codes. Read similar threads in this forum for additional information.
