Good Day,
I am about to install AutoCAD 2013 x64 that came with my AutoDesk Product Design Suite Ultimate. I noticed that it is has its pwn installer, but is it part of the Suite?
Would I use the same serial number and the suite product key or same serial number and the AutoCAD product key for 2013?
Sean
Solved by jessica.t. Go to Solution.
So I found this on the Autodesk Website:
Product keys are required for installation of Autodesk products and are used to differentiate products that are both sold independently and as part of a product suite. For example, installing AutoCAD 2013 as a point product requires product key 001E1, but installing AutoCAD 2013 from the Autodesk Product Design Suite Ultimate 2013 requires product key 781E1. The same version of AutoCAD is in both software packages but the product key differentiates one package from the other.
So I did use the suite product key and installed with no issues...I googled for a half hour and could not come up with anything, but then I googled product keys for Autodesk and found that paragraph above. Perfect use of office time. haha...
Sean
Welcome to the community Mohau!
What product key are you using for your AutoCAD 2014 installation? 001F1?
autodesk has all 2013 product keys on their website
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19726931&linkID=12305695
DarrenP
Hi aarifmalik,
I have removed the serial number from your post. Please do not post your product's serial number on public web spaces such as this and other forums.
Are you having issues activating your AutoCAD 2013? If so, please provide us with more details on the issue, such as error messages.
Thank you,
