AUTOCAD2020 SERIAL NUMBER
mdynm21
Message 1 of 15
mdynm21
Community Visitor
Community Visitor
I NEED SERIAL NUMBER FOR AUTOCAD2020
Replies (14)
Message 2 of 15
ChicagoLooper
This is how you lookup YOUR serial number:
  1. On command line, enter ABOUT->Enter
  2. Click Manage License button
  3. Click the AutoCAD icon=>YOUR serial number will be displayed
Chicagolooper
Message 3 of 15
ennujozlagam
do you have a legit autocad software or just asking for a serial number to run the program? you can check with your autodesk subscription account if you have a legit autocad and look for serial number or ask autodesk technical support? thanks
Message 4 of 15
mdavis22569
@mdynm21
I would look in your Account Manager and see what is shows.
If you have a valid subscription, it'll show either a serial number or it'll show a SIGN IN message for the activation.
Mike Davis
Message 5 of 15
mdavis22569
@mdynm21
Were you able to get this resolved?
Mike
Mike Davis
Message 6 of 15
mdavis22569
@mdynm21
Doing one quick follow-up... did you find your solution with what's been posted so far?
Mike
Mike Davis
Message 7 of 15
YoniYoye
Community Visitor
Community Visitor
i need a serial number auto cad 2020
Message 8 of 15
CGBenner
@YoniYoye
Welcome!  Have you read the suggestions offered in the other posts on this thread?
Chris Benner
Message 9 of 15
mdavis22569
@YoniYoye
2020 is now a Sign In Activation. If you're on subscriptio, just sign in with your Autodesk ID and activate it.
Any reason you don't want to use 2025 or 2026 the newest versions?
Mike Davis
Message 10 of 15
biolosy2207
Community Visitor
Community Visitor
i need autocad 2020 serial number
Message 11 of 15
mdavis22569
If you have a legacy purchase or old license, it'll be in your account portal. However, if you're on a subscription, you're on a named user activation, and 2020 isn't available anymore.
Mike Davis
Message 12 of 15
chandumerawat1992
Community Visitor
Community Visitor
Message 13 of 15
mdavis22569
Unfortunately @chandumerawat1992 2020 isn't supported anymore.
If you have a perpetual license, then the serial number will be in your Account Portal for it.
But Autodesk has moved away from Serial numbers prior to this for the most part. It would be a named user sign in.
Hope this helps.
Mike Davis
Message 14 of 15
pendean
Community Legend
Community Legend
If you cannot find it when you log in here, you are out of luck and probably need to find an alternate CAD program if you are not able to pay for new subscriptions
https://manage.autodesk.com/products/all
Message 15 of 15
arslanmughal1937
Community Visitor
Community Visitor
hi
