This is how you lookup YOUR serial number:
Chicagolooper
do you have a legit autocad software or just asking for a serial number to run the program? you can check with your autodesk subscription account if you have a legit autocad and look for serial number or ask autodesk technical support? thanks
I would look in your Account Manager and see what is shows.
If you have a valid subscription, it'll show either a serial number or it'll show a SIGN IN message for the activation.
Were you able to get this resolved?
Mike
Doing one quick follow-up... did you find your solution with what's been posted so far?
Mike
@YoniYoye
Welcome! Have you read the suggestions offered in the other posts on this thread?
Did your question get successfully answered? Then just click on the 'Accept solution' button. Thanks and Enjoy!
Chris Benner
2020 is now a Sign In Activation. If you're on subscriptio, just sign in with your Autodesk ID and activate it.
Any reason you don't want to use 2025 or 2026 the newest versions?
i need autocad 2020 serial number
If you have a legacy purchase or old license, it'll be in your account portal. However, if you're on a subscription, you're on a named user activation, and 2020 isn't available anymore.
