Using a macro to get angle of line
Message 1 of 9
add Line "1"                line with name 1 was created befor
LET x = line[1].??????    which command to get the angle
LET a = $x*2
MODIFY
APPARENT $a
ACCEPT
I found command for curve but i need for line
compcurve[name].point[name].entry_tangent.azimuth
or why don't work command add line"1" in next macros (line with name 1 was created befor):
INPUT POINT 'Position of centre' $cenpos1
create workplane SINGLE
POSITION
X $cenpos1_x
Y $cenpos1_y
Z $cenpos1_z
ACCEPT
MODIFY
XAXIS DIRECTION
add line"1"           I have to use command : input free , and  select the line by myself, it is not very good for me
ACCEPT
ACCEPT
Replies (8)
Message 2 of 9
Here you have the solution:
Angles of a line
Use the following variables for finding the apparent and elevation angles of a line (these are the same values as shown on the line editing form).
The commands return a REAL value, with the angle in the current units - degrees or radians).
LINE[xxx].APPARENT
returns the apparent angle of the line using the current working plane of the currently active workspace
LINE[xxx].ELEVATION
returns the angle of elevation that the line makes using the current principal plane of the currently active workspace.
You can optionally specify which principal plane to use:
LINE[xxx].APPARENT.XY
LINE[xxx].APPARENT.YZ
LINE[xxx].APPARENT.ZX
LINE[xxx].ELEVATION.XY
LINE[xxx].ELEVATION.YZ
LINE[xxx].ELEVATION.ZX
I checked the second macro and it works well, I don't have any problems.
Mateusz
Message 3 of 9
if I run macro step all :
add Line "1"
LET x = LINE[1].APPARENT.XY
LET a = $x*2
MODIFY
APPARENT $a
ACCEPT
I have error after second line : invalid command = LET x = LINE[1].APPARENT.XY
Message 4 of 9
I tried to run this macro and it works perfectly.
Don't you have variable 'x' already defined?
Try to change the name of variable, e.g. 'x1', 'a1'...
Mateusz
Message 5 of 9
changing the name of variable don't help? I work i Power Shape 2010 and you? could differen version make affect the outcome
Message 6 of 9
maybe I need to declare type of variable first ?
Message 7 of 9
can you run this full macros in new model
VIEW EDIT TOP
CREATE LINE
 SINGLE
 -63, -24, 0
 97, 44, 0
select clearlist
create datum
SINGLE
 -63, -24, 0
MODIFY
XAXIS DIRECTION
add Line "1"
ACCEPT
ACCEPT
select clearlist
 add Line "1"
MODIFY
APPARENT -10
ACCEPT
select clearlist
add Workplane "1"
MODIFY
XAXIS DIRECTION
add line "1"
ACCEPT
ACCEPT
select clearlist
VIEW EDIT TOP
it have to create line, then workplane, then rotate workplane like line direction, then turn line on -10, and again rotate workplane like line direction but when I run macros workplane don't rotate? why!!!!!!!????????????Smiley Sad
Message 8 of 9
I'm working at PowerSHAPE 2015.
Mateusz
Message 9 of 9
Easier way to get angle of line.
let $lin = selection.name[0]
let $b = LINE[$lin].APPARENT
PRINT ERROR' The line angle is... '$b ' Degrees'
