Level Used Highlighter
a1moldmaker
Message 1 of 8
a1moldmaker
request for functionality
i use the level manager constantly and it would be very helpful if the levels used would be highlighted or shaded to indicate that they contain objects.
Currently i filter by "used" and "named", but this does nothing to tell me what levels have objects on them.
If i turn off "named" then i am forced to remember what each level name/number combination is out of dozens of them.
By simply having the level be highlighted or shaded i could see the names of each level and know if it has objects on it without switching the filters constantly.
Bruce Green
Saying I cant always leads to failure
Saying I tried MIGHT lead to success
Replies (7)
Message 2 of 8
jon.hunwick
Great idea, Bruce. I will forward this to the development team.
Jon Hunwick
Message 3 of 8
If I remember correctly you asked in the past about macro to search and delete empty lvls. Here is the code of this macro:
LET lvl_num = 997
LET counterUsedLvls = level.number - 1
while $counterUsedLvls {
	IF level[$lvl_num].used == '0' {
		LET renameLevel = concat('LEVEL RENAME '; $lvl_num)
		EXECUTE COMMAND $renameLevel
		TOOLBAR LEVEL OFF $lvl_num
	} ELSE {
		LET $counterUsedLvls = $counterUsedLvls -1
	IF $counterUsedLvls == $lvl_num {
		BREAK
	LET $lvl_num = $lvl_num - 1
PRINT ERROR 'Empty levels removed.'
Is that not enough for you?
Mateusz
Message 4 of 8
jitendra.chaudhari
Hi @a1moldmaker
Thanks for Contacting Autodesk Community Forum..
I have forwarded the above feature request to Autodesk PowerShape development team through a change request. I would keep you posted for the major updates on this feature request.
Thanks for your time and raising a feature request for Autodesk PowerShape.
Jitendra Chaudhari.
Message 5 of 8
a1moldmaker
piro_man
that macro works get and i use it all the time,
but what i am asking for now is a way to know if a level has objects on it by looking at the level manager.
for example in another software there is a column that tells how many objects are on each level.
i am not concerned with how many things are on a level, but more importantly to me is IF a level has anything on it
i work with a predefined level structure to begin with, but as each job is different, there are times when i will replace a unused level name with something needed for the current job
right now i have to turn on a level to see if it is empty or not, all of this is done manually and a macro will not help with it
Bruce Green
Message 6 of 8
a1moldmaker
thanks buddy
Bruce Green
Message 7 of 8
a1moldmaker
any word on if this can be added?
Bruce Green
Message 8 of 8
a1moldmaker
hoping this is a easy thing and makes it in soon
Bruce Green
