hi,
is there a way to force the snap point ?
eg:
if i've a line that intersects another line and the mid points is near to intersection point and i need to create a circle in the intersection point in this case i must zoom very well to select the correct point.
There is a way to force only intersection point ( ignoring the mid point ) ?
thanks
Solved by jon.hunwick. Go to Solution.
The Screencast below shows how to use the Point dialog to do this.
Pressing Tab does an auto-zoom to the current cursor position. If you were to increase the zoom factor from its default, which is 2, to 10 or something, that might help, too.
thanks but isn't a good solutione for my.
i've many wireframe ( line curve compcurve ) and I need to place a circle in some known points ( start and end of line , intersection from a composite curve and line etc etc ) and a good snap solving my problem !
I will raise a development Wish for this. We have several snap filters already, but not one that looks for 'intersections' only.
thanks,
yes, there is many snap but all in one ( key points: start, end, centre etc etc ) but is not possibile to set only start points or only end points or only intersection points)
