Fatal error exporting to .igs file in 2022 & 2023
keith.johnsonXMJK2
keith.johnsonXMJK2
Hi , I am having issues exporting files as .igs format especially lager format files. 100M and above, i get the following errors.
All surfaces are correctly trimmed and there are no errors when I run  the file doctor.
Any help would be appreciated, I was thinking that there could be a conflict between PS2022/2023 and the subsequent exchange utilities, if I am using PS2022, but exchange 2023 is being used in the translation process?
Thanks in advance
__Luca__
the same issue here, i have an open development case ( DCDOP-4003 ).
For large files we are blocked at Exchange 2021.
Regards
marcio.sivieroJ9VUX
Observer
Observer
Hi.
The same issue here as well.
Marcio Siviero
glen_h
Same issue here. Any solution yet?
Using Powershape 2021 and AMDEU 2026
Powershape will give the same errors as pictured above...if I even get that far without my PC completely becoming unusable.
Glen
Big thanks to all who contribute!
My opinions are my own and are not intended to reflect yours.
