PowerShape Forum
Welcome to Autodesk’s PowerShape Forums. Share your knowledge, ask questions, and explore popular PowerShape topics.
Dark theme
16 REPLIES 16
Message 1 of 17
PLAS1991
1961 Views, 16 Replies
Dark theme
I suggest implement Dark theme to PowerShape as in AutoCAD. Powershape interface is too light now and after hours of working, eye strain is huge. Thank you
16 REPLIES 16
Message 2 of 17
jon.hunwick
in reply to: PLAS1991
Are you talking about the icons, or the screen background?
Jon Hunwick
Message 3 of 17
PLAS1991
in reply to: jon.hunwick
Message 4 of 17
jon.hunwick
Hello @PLAS1991
At present there is only one theme implemented.
Jon Hunwick
Message 5 of 17
Yes good idea, health before
Message 6 of 17
wmtool
This is high on my wish list. Any possibility this could happen at some point?
Or is there any way to go into program files and make changes to get the dark effect?
I believe PowerMill already has it.
Message 7 of 17
ChristopherMarion
in reply to: wmtool
No option as of yet for dark mode or theme in PowerShape....or PowerMill.
The only option would be to change the background colour to black, but the surrounding ribbon would not be affected.
Christopher Marion
Technical Specialist - CAM
SolidCAD - Canada
Message 8 of 17
wmtool
in reply to: ChristopherMarion
OK Thanks
Is there a way to change the ribbon colors by editing setup files?
Message 9 of 17
ChristopherMarion
in reply to: wmtool
Hi @wmtool
As far as I know.....no.  I do not know of any system files that can be altered to change this.
Christopher Marion
SolidCAD - Canada
Message 10 of 17
wmtool
Hello
I just got help from support with this.
If you run a macro with the line                       ribbon_debug theme 17
it will put the ribbons into dark mode.
Also substitute the 17 for numbers 1 to 30 and there are a lot of other nice ribbon color options.
Thanks to support for help.
Message 11 of 17
ChristopherMarion
in reply to: wmtool
Hi @wmtool
Fantastic.  Do you know if this works in PowerMill as well?
Christopher Marion
SolidCAD - Canada
Message 12 of 17
wmtool
Yes it works in PowerMILL also.
Message 13 of 17
ChristopherMarion
in reply to: wmtool
Hi @wmtool
I got it to work in PowerShape, but not PowerMill.  Different command perhaps?
Also, why is this not widely known?  Thank you for changing my life 🤣
Christopher Marion
SolidCAD - Canada
Message 14 of 17
wmtool
My support contact told me it worked in PowerMILL although I have tried it.
Guess your right it must be a different command. I also don't know why this
isn't more widely
know it's very useful. I had carefully searched the help menu and didn't
find anything on the subject.
Guess you learn something new every day.
Message 15 of 17
ChristopherMarion
in reply to: wmtool
Hi @wmtool
Well, I'd imagine it is possible in PowerMill as well if this an option in PowerShape/PowerMill Modelling.
Much appreciated.  I'll look into the PowerMill option.  I'll update this if I get anywhere with it.
Christopher Marion
SolidCAD - Canada
Message 16 of 17
you can change the powermill theme.
there are 3 available.
I am attaching a small macro for choosing options
Function Main() {
STRING ARRAY $Group[] = {"Default","White","Colorful","Dark Gray"}
INT C = INPUT CHOICE $Group "Pick an option"
IF $C == 0 {
FORM RIBBON STYLE DEFAULT
IF $C == 1 {
FORM RIBBON STYLE OFFICE_2016_WHITE
IF $C == 2 {
FORM RIBBON STYLE OFFICE_2016_COLORFUL
IF $C == 3 {
FORM RIBBON STYLE OFFICE_2016_DARK_GRAY
Greetings
Message 17 of 17
Hi @newchris23
Yes, found out shortly after that last post that it was possible to set up different themes in PowerMill.  I also created a similar macro.  I definitely do not like the dark theme in PowerMill as it makes things difficult to see.  I prefer the "colourful" option actually.
Thanks for adding this for everyone else though!  Much appreciated.
Christopher Marion
SolidCAD - Canada
