Solved by jon.hunwick. Go to Solution.
This is high on my wish list. Any possibility this could happen at some point?
Or is there any way to go into program files and make changes to get the dark effect?
I believe PowerMill already has it.
No option as of yet for dark mode or theme in PowerShape....or PowerMill.
The only option would be to change the background colour to black, but the surrounding ribbon would not be affected.
OK Thanks
Is there a way to change the ribbon colors by editing setup files?
Hello
I just got help from support with this.
If you run a macro with the line ribbon_debug theme 17
it will put the ribbons into dark mode.
Also substitute the 17 for numbers 1 to 30 and there are a lot of other nice ribbon color options.
Thanks to support for help.
Hi @wmtool
Well, I'd imagine it is possible in PowerMill as well if this an option in PowerShape/PowerMill Modelling.
Much appreciated. I'll look into the PowerMill option. I'll update this if I get anywhere with it.
Hi @newchris23
Yes, found out shortly after that last post that it was possible to set up different themes in PowerMill. I also created a similar macro. I definitely do not like the dark theme in PowerMill as it makes things difficult to see. I prefer the "colourful" option actually.
Thanks for adding this for everyone else though! Much appreciated.
