Create curve by using center of toolpaths, Patterns or workplanes using API in VB.net
anton.vendland
anton.vendland
I need generate center curve from center points of set of toolpaths or set of patterns or set of workplanes.
If with workplanes, I need create workplane eather from toolpath or Pattern.
I am using PM API with VB.net
Thank you if any help.
anton.vendland
old API was:
Dim oCurve As Curve
Set oCurve = PowerMILL.ActiveProject.Curves.CreateCurveFromPoints(PowerMILL.ActiveProject.Workplanes("WP1"), _
PowerMILL.ActiveProject.Workplanes("WP1"), CurveType:=CurveLine, _
CurveMethod:=CurveCentrePointPattern, nSegments:=10, Tolerance:=0.1, _
Points:=Array(Point(0, 0, 0), Point(1, 0, 0), Point(2, 0, 0)))
luke.edwards.autodesk
Hi Anton, I'm not sure whay you mean about the old API. I don't recognise some of the constructs you have there. Do you mean you want to create a curve in PowerShape that represents the toolpath?
Luke Edwards
Consulting Services Manager
anton.vendland
Hi Luke, I need use PM for curve creation.
It could be method collecting center points from Planes, tollpath or patterns.
And then creating curves by points or any other methods.
Thank you
Hi. You can create a Pattern or a Boundary from a Polyline, Spline or PIC file using the various functions on the PowerMill.ActiveProject.Patterns and PowerMill.ActiveProject.Boundaries collections.
A Polyline and Spline can be created from a list of points (that might come from centre points of planes, workplanes etc as you mention). A PIC file can be created by exporting curves and toolpaths to PIC files and then importing into the Pattern or Boundary.
I hope this makes sense, I'm still a little unclear on exactly what you are trying to achieve.
Luke Edwards
anton.vendland
That is my target
