connect to one of posermill processes using the clsPowerMILLOLE
sk7998.ryu
sk7998.ryu
Is there a way to connect to a specific PowerMill process using the connect() command in clsPowerMILLOLE when there are several processes of PowerMill running?
luke.edwards.autodesk
Hi, this API was deprecated years ago in favour of this one:
https://github.com/Autodesk/PowerShapeAndPowerMillAPI
You can consume it into your projects using NuGet. Information on this can be found on this forum.
You can then use the PMAutomation class to get a list of running instances. Choose which one you want and call the PMAutomation constructor to connect to it.
Hope this helps.
Luke Edwards
Consulting Services Manager
