PowerMill API - How to solve "Autodesk.ProductInterface.PowerMILL.PMAutomation" problem when accessing "powermill.Options.Tool.Database.FileName"
patrick_lam
Message 1 of 9
patrick_lam
Dear Sir,
Could you please advise how solve the compiling problem of code involving parameter "powermill.Options.Tool.Database.FileName"? The compiling problem message is:
- Error 4 'Options' is not a member of 'Autodesk.ProductInterface.PowerMILL.PMAutomation'. ...
Best Regards, Patrick.
Replies (8)
Message 2 of 9
luke.edwards.autodesk
Hi, I'm confused about what you refer to. Can you share more information on the code? Are you compiling you own version of the API?
Luke Edwards
Consulting Services Manager
Message 3 of 9
patrick_lam
Dear Luke,
Sorry for confusing you.
I am writing a PowerMill Apps by API and woud like to read and edit the PowerMill parameter.
During the build of the solution, Visual Studio prompts the error message.
Message 4 of 9
Can you share a screenshot of your code?
Luke Edwards
Message 5 of 9
patrick_lam
Here it is:
Message 6 of 9
Ok, so that just doesn't exist as a property available through the API. Where did you get the indication that the "Options.Tool.Database.FileName" parameter was something that could be accessed?
Luke Edwards
Message 7 of 9
patrick_lam
By this way:20230314-02.png20230314-03.png
Message 8 of 9
Ok, so I think the only way you could get that is to do:
powermill.ExecuteEx("print $powerMill.Options.Tool.Database.FileName")
Luke Edwards
Message 9 of 9
patrick_lam
Thanks a lot, Luke.
