PowerMill Forum
Welcome to Autodesk’s PowerMill Forums. Share your knowledge, ask questions, and explore popular PowerMill topics.
UMC 5-axis posting taps wrong
16 REPLIES 16
Message 1 of 17
927 Views, 16 Replies
I've been told by our machinist that our UMC is posting out demicals wrong. The Feeds and Speeds for our taps we usually do 1000 x metric pitch for cutting rate. Eg. for a 3/8-16 tap we do 1587.5 cutting rate. Whenever the NC program is written out of Powermill 2018 / 2019, the UMC post reads 1.5875 for the cutting rate. Is there a quick fix for this?
16 REPLIES 16
Message 2 of 17
iamcdn79
Does this topic help you?
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
Message 3 of 17
in reply to: iamcdn79
Is that Item Properties located in Powermill or on the console of the machine? I'm new to all of this.
Message 4 of 17
iamcdn79
It's found by using your post and postprocessor software. If you have never attempted this you could upload your post on here or email it to me and I can change it for you
Windows 11 Pro
Message 5 of 17
I'm a little lost, so to fully understand, so we post our NC Programs from Powermill to the UMC. Would this software be powermill ?
Message 6 of 17
iamcdn79
No, its a program called Autodesk Manufacturing Post Processor Utility 2019. That is where you make changes to your post
Windows 11 Pro
Message 7 of 17
Oh sweet yes I have that, how do I get to the item properties you posted on the linked forum?
Message 8 of 17
iamcdn79
Watch this video, and either change the imperial or metric parameter
Windows 11 Pro
Message 9 of 17
Okay, I followed the video and now I'm uncertain if that is what is causing tap feed rates to move from 1275 to 1.275. Attached is our post that we use for the UMC.
Message 10 of 17
iamcdn79
Is it just in rigid tapping you have this problem? It looks to display the feedrate as expected. For just regular tapping you have the feedrate set to never output to tape. Is it ok for deep drilling? Can you upload your project that is giving the bad result as well?
Windows 11 Pro
Message 11 of 17
I was told it was for the Tapping not Rigid Tapping. It seems to have this issue on any project, not a certain one. So my guessing is, it might be that Tapping has never on the output?
Message 12 of 17
rafael.sansao
Try this:
Rafael Sansão
Message 13 of 17
iamcdn79
Do you maybe have a leadin % factor set to something less that 100% in your feeds and speeds?
Windows 11 Pro
Message 14 of 17
Our Lead in in 100%. I'm going to try Refael's fix. Will post if it helps.
Message 15 of 17
Thank you for your time. The decimal issue has been solved.
Message 16 of 17
in reply to: rafael.sansao
What all did you change on the post program? So, if this happens again I can fix it.
Message 17 of 17
rafael.sansao
To find out what has changed, use PostComparer:
C:\Program Files\Autodesk\Manufacturing Post Processor Utility 2018\PostComparer.exe
Rafael Sansão
