Tips & Tricks
Tips & Tricks
GlennM.MCAM
Message 1 of 99
Tips & Tricks
GlennM.MCAM
Hi all!
I thought it would be a good idea to post some tips and tricks for certain actions. Some of you will know them, other don't.
Please post as much tips & tricks as you want. Here are mine:
Since it is not possible to export the stockmodel as a dmt file, I save the viewmill state as dmt and use that as a block.
If you need a selection of your model and want to save this selection, use this macro:
CREATE LEVEL ; MODELCOMPSET EDIT LEVEL # ACQUIRE SELECTED
Greetings,
Glenn
Intel i7 4790 @ 3.60GHz -16GB RAM - Nvidia Quadro K620 - 250GB SSD - Win 7 Pro x64 SP1
PowerMILL Premium 2019.1 - PowerINSPECT Ultimate OMV 2017 SP6
Replies (98)
Message 2 of 99
kukelyk
//save stockmodel as STL, load as 3d block
STRING stkmd = ""
IF NOT ENTITY_EXISTS('stockmodel','') {
	IF size(FOLDER('stockmodel')) == 0 {
		MESSAGE INFO "There is no stockmodel in the project.."
		MACRO ABORT
	} ELSEIF size(FOLDER('stockmodel')) == 1 {
		$stkmd = (FOLDER('model')[0]).Name
		ACTIVATE STOCKMODEL $stkmd
	} ELSE {
		//there are more stockmodels
		$stkmd = INPUT ENTITY STOCKMODEL "Select stockmodel:"
} ELSE {
	$stkmd = $ENTITY('stockmodel','').Name
STRING stlfile = project_pathname(0) + "_" + $stkmd + ".stl"
EXPORT STOCKMODEL_SHADING ; $stlfile
EDIT BLOCK COORDINATE WORLD
EDIT BLOCKTYPE TRIANGLES
GET BLOCK $stlfile
BLOCK ACCEPT
UNDRAW StockModel $stkmd
Message 3 of 99
GlennM.MCAM
STRING stkmd = ""
		MACRO ABORT
	} ELSE {
} ELSE {
GET BLOCK $stlfile
BLOCK ACCEPT
Triangulation of the stockmodel takes a very long time. The model I am working with now will take an hour to triangulate Smiley Sad
Message 4 of 99
kukelyk
Viewmill simulation takes more time, I think..
Message 5 of 99
iamcdn79
I hope this topic gets a lot  more replies than the old forum page especially from delcam/autodesk staff
Here's my 2 cents... trimming macro that lets you create, edit, transform more than 1 trimming boundary. A lot more powerful than the current default one
CREATE BOUNDARY ; SKETCH
EDIT BOUNDARY ; CURVEEDITOR START
CURVEEDITOR MODE LINE_MULTI
then another one to decide to keep inside or outside
CURVEEDITOR FINISH ACCEPT
BOOL $side = 0
$side = query "Do you want to Keep Inside?"
EDIT TOOLPATH LIMIT BOUNDARY
EDIT TOOLPATH LIMIT BOUNDARYNAME ;
EDIT TOOLPATH LIMIT BOUNDPLANEOPTIONS VIEW_PLANE
EDIT TOOLPATH LIMIT DELETE N
IF $side {
  EDIT TOOLPATH LIMIT KEEP INNER
} ELSE {
  EDIT TOOLPATH LIMIT KEEP OUTER
PROCESS TPLIMIT
DELETE BOUNDARY ;
Wish there was a way to have both macros run as one but as far as I know there isn't
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
Message 6 of 99
kukelyk
//Create plane from block, on the height of a selected point
REAL Z= 9898
$EdgeBreakWidth = $Z
WHILE $Z == 9898 {
	MODE OBTAIN ZHEIGHT 'EdgeBreakWidth'
	$Z = $EdgeBreakWidth
MODE CANCEL
CREATE PLANE ; $Z
Message 7 of 99
NanchenO
Update all the blocks, according to their types:
// Macro pour mettre a jout les bruts
// Close the logfile if it was left open from a previous macro
DIALOGS MESSAGE OFF
FILE CLOSE logfile
DIALOGS MESSAGE ON
// Deletes the old results
DELETE FILE C:\temp\brut.txt
STRING logfile = "C:\temp\brut.txt"
// Open (Overwrite) the file specified by the user
FILE OPEN $logfile FOR WRITE AS logfile
STRING $head = 'Resume de la macro'
FILE WRITE $head TO logfile
$head = ' '
STRING $brut = ''
STRING $path = ''
STRING $Rep = ''
STRING $data = ''
STRING $upd = ''
STRING $oldpath=''
STRING $oldrep=''
BOOL $frontiere = 0
REAL $max = 99999.999
REAL $min = -99999.999
EDIT PREFERENCE SELRAISEFORM NO
DEACTIVATE TOOLPATH
FOREACH ent IN folder("TOOLPATH") {
	ACTIVATE TOOLPATH $ent
	If $Toolpath.Block.Type == "triangles" {
		If $brut == '' {
			$brut = FILESELECT "Selectionner le nouveau brut" "*.dmt; *.prt.*"
			$path = "'" + $brut + "'"
		If $Rep == '' {
			$Rep = INPUT ENTITY WORKPLANE "Selectionner le plan de travail du brut"
		$oldpath=$toolpath.Block.FileName
		$oldrep=$toolpath.Block.NamedWorkplane.Name
		//If $oldpath!= $path {
			If $Statistics.CuttingMoves.Lengths.Linear != 0 {
				INVALIDATE TOOLPATH $ent
				YES
			EDIT TPPAGE SWBlock
			EDIT BLOCK COORDINATE NAMED
			EDIT BLOCK NAMEDWORKPLANE $Rep
			$ent.Block.FileName = $brut
			GET BLOCK $brut
			BLOCK ACCEPT
			DRAW BLOCK
			EDIT BLOCK UPDATEFORM
			EDIT TOOLPATH $ent REAPPLYFROMGUI
			YES
			$data = ($toolpath.name + ', Type : ' + $toolpath.Block.Type + ', Repere : ' + $Rep + ', Fichier : ' + $path)
			FILE WRITE $data TO logfile
			$data = ('')
			//} else {
			//$data = ($toolpath.name + ', Type : ' + $toolpath.Block.Type + ', Repere : ' + $Rep + ', Fichier : ' + $path)
			//FILE WRITE $data TO logfile
			//$data = ('')
	If $Toolpath.Block.Type == "box" {
		IF entity_exists(Boundary) {
			BOOL $frontiere = 1
				YES
			EDIT TPPAGE SWBlock
			EDIT BLOCKTYPE BOX
			EDIT BLOCK NAMEDWORKPLANE $toolpath.workplane.name
			EDIT BLOCK LIMITTYPE BOUNDARY
			EDIT BLOCK RESET
			EDIT BLOCK ZMIN UNLOCK
			EDIT BLOCK ZMAX UNLOCK
			$max = ($ZRange.Maximum.Value + 1.0)
			$min = ($ZRange.Minimum.Value - 1)
			EDIT BLOCK ZMIN $min
			EDIT BLOCK ZMAX $max
			EDIT BLOCK ZMIN LOCK
			EDIT BLOCK ZMAX LOCK
			EDIT BLOCK RESET
			STRING $data = ($toolpath.name + ', Type : ' + $toolpath.Block.Type + ', Frontiere : ' + $Boundary.Name + ', Zmax ' + $max  + ', Zmin ' + $min)
			$data = ('')
		} Else {
		STRING $data = ($toolpath.name + ', Type : ' + $toolpath.Block.Type + ', PAS DE FRONTIERE !!! -> PAS TRAITE !!!')
		$data = ('')
	If $Toolpath.Block.Type == "cylinder" {
			BOOL $frontiere = 1
				YES
			EDIT TPPAGE SWBlock
			EDIT BLOCKTYPE CYLINDER
			EDIT BLOCK RESET
			EDIT BLOCK RESET
			$data = ('')
		} Else {
		$data = ('')
	If $Toolpath.Block.Type == "boundary" {
			BOOL $frontiere = 1
				YES
EDIT TPPAGE SWBlock
	EDIT BLOCKTYPE BOUNDARY
	EDIT BLOCK RESET
	REAL $max = ($ZRange.Maximum.Value + 1.0)
	REAL $min = ($ZRange.Minimum.Value - 1)
	EDIT BLOCK RESET
	EDIT TPPAGE SWBlock
	EDIT BLOCK RESET
	EDIT BLOCK RESET
			$data = ('')
		} Else {
		$data = ('')
	If $Toolpath.Block.Type == "picture" {
		STRING $data = ($toolpath.name + ', Type : ' + $toolpath.Block.Type + ', TYPE IMAGE -> PAS TRAITE !!!')
		$data = ('')
	DEACTIVATE TOOLPATH
	DEACTIVATE BOUNDARY
EDIT PREFERENCE SELRAISEFORM YES
FILE CLOSE logfile
OLE FILEACTION 'open' $logfile
Olivier
Message 8 of 99
kukelyk
What is the goal of the update? Especially if Your toolpaths will be deleted?
Message 9 of 99
NanchenO
Since our parts are similar, but never exactly the same, we copy a project under a new name, delete the model, correct the boundaries, curves, patterns... and the blocks. Then we just have to calculate the toolpathes and check them.
That is the goal of this macro.
Olivier
Message 10 of 99
iamcdn79
To avoid getting the message that the second point doesn't lie on the same plane when creating a rectangle boundary, hold down the ctrl key
Windows 11 Pro
Message 11 of 99
iamcdn79
To go directly to the bottom of your explorer tree hit the "End" button on your keyboard
To go to the top hit "Home"
To go incrementally up or down hit "Page Up" or "Page Down"
Windows 11 Pro
Message 12 of 99
GlennM.MCAM
last friday I managed to toggle the drawing of the tool with 1 key (In my case this is F8 but you can choose whatever you want).
This is what I've done: I have 3 macro's. Each macro has it's own function: draw tool, draw tool shaded and undraw tool.
At the end of each macro, the keyshortcut is changed to the next macro (= next tool draw)
To get this working save the 3 macro's below (change the path to the correct location!) and then you need to manualy run 1 of the 3 macro's in the navigation menu in order to get the F8 key assigned . After this you just press F8 and it toggles the drawing of the tool.
No toolpaths need to be active.
These are the 3 macro's:
Draw tool, no shade (ToolDraw.mac)
//DRAW TOOL
UNDRAW SHADEDTOOLS
DRAW TOOL $Toolpath.Tool
//DELETE PREVIOUS ASSIGNMENT
FORM CUSTOMKEYBOARD
CUSTOMKEYBOARD SELECT MACRO "L:\...\ToolDraw.mac"
CUSTOMKEYBOARD DELETE SELECTED
//SET SHORTCUT F8 TO DRAW TOOL SHADED
CUSTOMKEYBOARD ADD MACRO
CUSTOMKEYBOARD MACRO FILEOPEN
"L:\...\ToolDrawShaded.mac"
CUSTOMKEYBOARD SHORTCUT "0x77" //shortcut: F8
CUSTOMKEYBOARD ASSOCIATE
FORM ACCEPT CUSTOMKEYBOARD
Draw tool, shaded (ToolDrawShaded.mac)
//DRAW TOOL SHADED
DRAW SHADEDTOOLS
FORM CUSTOMKEYBOARD
CUSTOMKEYBOARD SELECT MACRO "L:\...\ToolDrawShaded.mac"
//SET SHORTCUT F8 TO UNDRAW TOOL
"L:\...\ToolUndraw.mac"
Undraw tool (ToolUndraw.mac)
//UNDRAW TOOL
UNDRAW TOOL ALL
FORM CUSTOMKEYBOARD
CUSTOMKEYBOARD SELECT MACRO "L:\...\ToolUndraw.mac"
Message 13 of 99
kukelyk
Great job.
These will be a bit faster if You modify like this:
//DRAW TOOL
UNDRAW SHADEDTOOLS
//FORM CUSTOMKEYBOARD //unnecessary code..
CUSTOMKEYBOARD MACRO "L:\...\ToolDrawShaded.mac" // //FILEOPEN unnecessary..
//FORM ACCEPT CUSTOMKEYBOARD //unnecessary code..
Message 14 of 99
iamcdn79
The selection tools 'select concave radii' selects all the red rads, to be able to select the green rads create a workplane that is rotated 180 in the Z to the model, make it active and pick 'select concave radii'
Windows 11 Pro
Message 15 of 99
gosmann.andreas
to del Bad Surfaces
UNDRAW LEVEL ALL
DRAW LEVEL "Bad Surfaces"
EDIT LEVEL "Bad Surfaces" SELECT ALL
DELETE MODEL SELECTED
DELETE LEVEL "Bad Surfaces"
DRAW LEVEL ALL
Message 16 of 99
danmic7JH66
Oohhhh, I'm going to use that.
Message 17 of 99
danmic7JH66
I export models that I've colored and fixed through powermill so I added this macro to a keyboard shortcut
// TURNS DIALOGS OFF
DIALOGS MESSAGE OFF
GRAPHICS LOCK
// DE-SELECTS ALL MODELS TO ENSURE YOU ARE EXPORTING THE ENTIRE // PART
EDIT MODEL ALL DESELECT ALL
// ASKS IF YOU MADE SURE THE LEVELS ARE CORRECT
string yesnoprompt = "DID YOU DELETE ALL OTHER MODELS, MAKE SURE THE LEVELS ARE CORRECT AND COPY THE MODEL NAME"
bool carryon = 0
$carryon = query $yesnoprompt
IF ($carryon == 1) {
// DELETES EMPTY LEVELS AND WORKPLANES
DELETE LEVEL EMPTY
DELETE WORKPLANE ALL
// TURNS DIALOGS ON
DIALOGS MESSAGE ON
GRAPHICS UNLOCK
// EXPORTS MODEL
EXPORT MODEL ALL FILESAVE
Using this macro saves me a lot of headaches for a couple reasons. If you have a surface selected powermill will only export out that specific surface. This macro ensures that doesn't happen.
Workplanes also export out on your model and this deletes them before it exports.
I also added a helpful yes no prompt to make sure that I followed my own process properly.
Message 18 of 99
GlennM.MCAM
@danmic7JH66 I have a variant on your macro. This one exports the model as a ddz file (to use in PowerInspect for example). If 2 or more models are present in the "Models" tree, you get a prompt to ask which one you want to export. It saves the file with the same name that is in the "Models" tree (if model is named "cad-model123" than it will be exported as "cad-model123.ddz". Planes are ignored.
STRING LIST models = {}
FOREACH md IN FOLDER('model') {
     IF position($md.name, "Planes") == -1 {
          INT k = add_last($models, $md.name)
STRING output_model = ''
IF size($models) == 1 {
     $output_model = $models[0]
} ELSE {
     $output_model = INPUT ENTITY MODEL "Choose model"
STRING ddz_filename = dirname(project_pathname(0), '/') +'/' +  $output_model + ".ddz"
EXPORT MODEL $output_model  $ddz_filename
MESSAGE INFO "Model Exported"
Message 19 of 99
danmic7JH66
I'll have to take a look at this when I get a few minutes! thanks!
} ELSE {
Message 20 of 99
danmic7JH66
Since I do all the data prep for my department, I like to define surfaces to chamfer for the guys.  The problem is it takes too long for me to trace a curve out in powershape and add it to a level (for macro selection) so I came up with this.
// TURNS DIALOG OFF
// DIALOGS MESSAGE OFF
FOREACH $pal IN folder('model') {
if position ($pal.name,"CAM") >= 0 {
FOREACH $mod IN folder('model') {
  STRING Lname = lcase($mod.name)
  if position ($lname,"cam") >= 0 {
    STRING path = pathname(mod)
    STRING base = basename(path)
STRING CHAMFERNAME = INPUT "NAME YOUR CHAMFER"
DELETE LEVEL EMPTY
CREATE PATTERN ;
EDIT PATTERN ; INSERT MODEL
EDIT PATTERN ; CURVEEDITOR START
MACRO PAUSE "VERIFY/EDIT CHAMFER SEGMENTS"
EDIT PATTERN ; CLIPBOARD COPY
CREATE MODEL CLIPBOARD
DELETE PATTERN ALL
CREATE LEVEL ; LEVEL
ACTIVATE LEVEL "1"
RENAME LEVEL "1" $CHAMFERNAME
EDIT LEVEL $CHAMFERNAME ACQUIRE SELECTED
EDIT MODEL "1" CLIPBOARD COPY
EDIT MODEL $BASE CLIPBOARD PASTE
DELETE MODEL "1"
EDIT LEVEL "Wireframes" SELECT ALL
DELETE LEVEL EMPTY
// TURNS DIALOG ON
// DIALOGS MESSAGE ON
What it does is creates a pattern off a selected surface, asks you to name the chamfer (for the level), pauses to edit the pattern however is needed in curve editor, converts the pattern to a model, copies the model, pastes it into the workpiece, and finally deletes the pattern model.
By doing this the programmers are able to see how I want things chamfered and I can macro it out.  Not sure how useful it'll be to anybody else but works fantastic for me.
