Tips & Tricks
Tips & Tricks
GlennM.MCAM
Message 1 of 99
Tips & Tricks
GlennM.MCAM
Hi all!
I thought it would be a good idea to post some tips and tricks for certain actions. Some of you will know them, other don't.
Please post as much tips & tricks as you want. Here are mine:
Since it is not possible to export the stockmodel as a dmt file, I save the viewmill state as dmt and use that as a block.
If you need a selection of your model and want to save this selection, use this macro:
CREATE LEVEL ; MODELCOMPSET EDIT LEVEL # ACQUIRE SELECTED
Greetings,
Glenn
Intel i7 4790 @ 3.60GHz -16GB RAM - Nvidia Quadro K620 - 250GB SSD - Win 7 Pro x64 SP1
PowerMILL Premium 2019.1 - PowerINSPECT Ultimate OMV 2017 SP6
Replies (98)
Message 61 of 99
Hey Glenn,
This Macro works great but I want to create a few If Else statements in here. I am trying to get the macro to decide which folder to place the file in. For example I have folders for each specific job. 6XXXX, 6AXXX, 6BXXX and so on. Right now this macro below will create only a 6XXXX folder and even if the part number is 6HXXX. It creates a directory like:
C:\Users\zwalker\Desktop\PROGRAMMED ELECTRODES\6XXXX\6H809\B Electrodes.
And I want it to create a directory like this:
C:\Users\zwalker\Desktop\PROGRAMMED ELECTRODES\6HXXX\6H809\B Electrodes.
In the past I have just simply replaced STRING X4 = "XXXX" with STRING X4 = "AXXX"  or STRING X4 = "BXXX" but I would rather not have a bunch of the same macro buttons on my ribbon when I could have one macro that does the deciding for me.
I want to be able to have PMILL Create a folder or if it exists already just get into the correct folder to create the correct save path.  I will post pictures below to hopefully better describe the scenario. I am not sure what terms I need to use to make this macro look at the line 16 (below) and have the macro determine whether this is an A, B, C, D or just another number.
STRING PATH2 = Substring("$ModelName", 1, 1)
Hopefully this makes sense to you as to what I am trying to accomplish. Thank you!
STRING LIST models = {}
FOREACH md IN FOLDER('model') {
     IF position($md.name, "Planes") == -1 {
          INT k = add_last($models, $md.name)
STRING ModelName = ''
IF size($models) == 1 {
     $ModelName = $models[0]
} ELSE {
     $ModelName = INPUT ENTITY MODEL "Choose model"
//Disect Model Name
STRING PATH1 = Substring("$ModelName", 0, 1)
STRING PATH3 = Substring("$ModelName", 0, 5)
STRING PATH4 = Substring("$ModelName", 6, 1)
STRING X4 = "XXXX"
STRING X3 = "XXX"
STRING ELECTRODE = $PATH4 + " Electrodes"
//Output path
STRING PATH0 = "C:\Users\zwalker\Desktop\Programmed Electrodes\" + $PATH1 + $X4 + "\" + $PATH3 + "\" + $ELECTRODE + "\" + $ModelName
STRING SaveAs = $PATH0
//if project already exist, just save it.
IF dir_exists($saveas) {
PROJECT SAVE
//if project doesn't exist, save it as modelname in model location
} ELSE {
		BOOL NameCheck = FALSE
		STRING $Question = "Is this path and modelname correct?" +CRLF+ $saveas
		$NameCheck = QUERY $Question
		IF $NameCheck {
		PROJECT SAVE AS $saveas
		STRING $Message = "Project has been saved in" +CRLF+ $saveas
		MESSAGE INFO $Message
Message 62 of 99
oh, sorry - i was run macros as macros
when i assigned macro to button - now it works
thanks 5axes!
Message 63 of 99
GlennM.MCAM
@Anonymous
Please post this question here because this topic is for tips & tricks Smiley Wink
At this time I don't have the time to work on that macro, but I think the easiest way to answer your question is adding a input dialog where you can manually enter '6', '7B', '8C', ... that will output the specific path OR you could use a list that gives you all the folders where you can select the correct one.
Auto detection macro are (for me) hard to make them bug free.
Glenn
Message 64 of 99
Beta_Librae
Would it be possible to have this macro prompt you for the export location?
Kind Regards,
Not cnc, you can call me Peabrain
Message 65 of 99
Beta_Librae
Good Morning,
Could the exported stockmodel file be directed to a specific/different folder? Could there be a choice for the user at the time of export?
Kind Regards,
Message 66 of 99
danmic7JH66
I had some help from members on this forum with my rename toolpaths macro and I figured I'd share it if anyone was interested! It starts by assigning a number to each toolpath and clearing out the rest of the name. Then it builds the new name based on tool number, tool diameter, toolpath type, and thickness. Feel free to use it how you see fit if it's helpful to anyone!
STRING RNM = ' '
INT CNT = 0
// CYCLES THROUGH ALL SELECTED PROGRAMS AND CLEARS THE NAME AND ASSIGNS A NUMBER
 FOREACH $Selected_Toolpath IN (explorer_selected_entities()) {
    // Exit if the selected entities are not Toolpaths
    IF $Selected_Toolpath.RootType != "toolpath" {
        BREAK
    MACRO APPERROR CONTINUE
// CLEARS THE TOOLPATH NAME AND ASSIGNS EACH ONE A NUMBER
IF CNT < 10 {
		$RNM = "0" + $CNT + "-"
	} ELSE {
		$RNM = $CNT + "-"
	RENAME Toolpath $Selected_Toolpath $RNM
	$CNT = $CNT + 1
	// DETERMINS TOOL DIAMETER AND ADDS THAT TO THE TP NAME
			BREAK
	ACTIVATE TOOLPATH $Selected_Toolpath
	// TOOLPATH NAME VARIABLE AND TOOLNUMBER VARIABLE
	STRING TPNAME = ENTITY('toolpath','').name
	INT TOONUM = ENTITY('toolpath','').tool.number
	STRING MISSEDTOOLNAME = ENTITY('tool','').name
	STRING TOOLNAME = ' '
	IF $TOONUM < 10 {
	$TOOLNAME = "T00" + $TOONUM + "-"
	} ELSE {
	$TOOLNAME = "T0" + $TOONUM + "-"
	IF $TOONUM == 0 {
	MESSAGE INFO "YOU FORGOT TO ADD A TOOLNUMBER TO TOOL... $MISSEDTOOLNAME , ADD TOOLNUMBER AND RESTART MACRO!"
	RENAME TOOLPATH ; "NO TOOL NUMBER"
	BREAK
	// TOOL DIAMETER VALUES
	STRING TOODIA = ENTITY('tool','').Diameter
	REAL TOOREA = $TOODIA
	REAL TOORND = ROUND ($TOOREA, 4)
	REAL TOOMET = $TOORND / 0.03937
	REAL METRND = ROUND ($TOOMET, 2)
	INT METINT = ROUND ($METRND, 1)
	// TOOLNAME VARIABLES
	// STOCK VARIABLES
	REAL THICC = Toolpath.Thickness
	STRING STOCK = ' '
	IF $THICC >= 0.015 {
	$STOCK = "ROUGH"
	IF $THICC < 0.015 AND $THICC >= 0.001 {
	$STOCK = "SEMI"
	IF $THICC < 0.001 {
	$STOCK = "FINISH"
	REAL FLTTHICC = Toolpath.AxialThickness
	STRING FLTSTOCK = ' '
	IF $FLTTHICC >= 0.015 {
	$FLTSTOCK = "ROUGH"
	IF $FLTTHICC < 0.015 AND $THICC >= 0.001 {
	$FLTSTOCK = "SEMI"
	IF $FLTTHICC < 0.001 {
	$FLTSTOCK = "FINISH"
		// NAME STRINGS BUILT FROM VARIABLES
		STRING NEWNAME = $TPNAME + $TOOLNAME
		STRING CHAMFERNAME = $NEWNAME + "CHAMFER"
		STRING SCRIBENAME = $NEWNAME + "SCRIBE"
		STRING DRILLNAME = $NEWNAME + $METRND + "MM_DRILL"
		STRING TAPNAME = $NEWNAME + $METINT + "MM_TAP"
		STRING HELINAME = $NEWNAME + $METINT + "MM_HELICAL-" + $STOCK
		STRING RASTERFLAT = $NEWNAME + $METINT + "MM_FLAT-" + $FLTSTOCK
		STRING OFFSETFLAT = $NEWNAME + $METINT + "MM_OFFSETFLAT-" + $FLTSTOCK
		// DECIDES WHAT TO NAME THE TOOLPATH BASED ON DIFFERENT TOOLPATH VARIABLES
		IF Strategy == "chamfer" {
		$NEWNAME = $CHAMFERNAME
		} ELSEIF Tool.Type == "taper_tipped" {
		$NEWNAME = $SCRIBENAME
		} ELSEIF Strategy == "drill" {
		IF toolpath.Drill.Type == "helical" {
		$NEWNAME = $HELINAME
			} ELSEIF toolpath.Drill.Type == 'tap_2' {
			$NEWNAME = $TAPNAME
				} ELSE {
				$NEWNAME = $DRILLNAME
		} ELSEIF Strategy == "raster_flat" {
		$NEWNAME = $RASTERFLAT
		} ELSEIF Strategy == "offset_flat" {
		$NEWNAME = $OFFSETFLAT
		} ELSEIF $TOOREA == 2.0 {
		$NEWNAME = $NEWNAME + "2_" + $STOCK
		} ELSE {
		$NEWNAME = $NEWNAME + $METINT + "MM-" + $STOCK
		RENAME TOOLPATH ; $NEWNAME
MESSAGE INFO "TOOLPATHS RENAMED"
Message 67 of 99
kandennti
Hi all.
I do not change the toolpath thickness when creating the electrode model toolpath I adjust it by adjusting the ThicknessSetValues.
Since it takes a lot of time to confirm ThicknessSetValues, I thought about a method to check with a macro.
In order to check as easily as possible, display the tool path name of
'Thickness Preferences' different from the specified tool path (or default) in the InfoBox.
However, it can not be determined that the [#] part (component) part is
exactly matched because of only numeric comparisons, but that comparison alone is enough for me.
If you want to compare with any toolpath, 'toolpath.XML' contains
<menupage label="Comparison with this Toolpath"
	command='MACRO Find_ThicknessSetValues_Unmatched_ToolPath.mac "%s"' />
</menupage>
If you want to compare with the Defaults
<menupage label="Comparison with Surface Defaults"
	command='MACRO Find_ThicknessSetValues_Unmatched_ToolPath.mac ""' />
</menupage>
Development and operation confirmation was done with PMill2018.
Message 68 of 99
jjohnybgood
Hi
Can this be modified to use in PM2016?
Thank you.
Message 69 of 99
5axes
@iamcdn79  a écrit :
Nice work, is there a way to get the draft angle displayed without having to hit F2 again? I would just like to pick a point and display that draft angle value
Finally, I modified my macro according to the request of @iamcdn79 .   You have to modify the time limit to stop the macro if you spend to much time to select the position on your model :
REAL $TLimit = 200  // Time Limit to select a position
// Measure and display Draft angle Value
// F2 to call the macro
//   -- F2 Each time you want to measure a new angle
// Version du 25/10/2017
// Version du 12/07/2018  rajout de la version avec 30s pour prendre le temps
FUNCTION MAIN() {
	VIEW MODEL ; SHADE UNDERCUT
	ECHO OFF DCPDEBUG UNTRACE COMMAND ACCEPT
	DIALOGS MESSAGE OFF
	MEASURE CLEAR_ALL MODE VECTOR START MEASURE DIRECTION
	MODE DIRECTION ALIGN GEOM
	BOOL $F_E=FALSE
	REAL $LIMIT_WHILE=0
        REAL $Timer = 0.25
	DO {
		WAIT $Timer
		$F_E=BOOL($widget('DirectionInput.Accept').Sensitive)
		$LIMIT_WHILE=$LIMIT_WHILE+$Timer
		IF $LIMIT_WHILE>$TLimit {
		    DIRECTION CANCEL
			MESSAGE ERROR "Exceeded time for point selection $TLimit : $LIMIT_WHILE"
			MACRO ABORT
	} WHILE NOT $F_E
	// Get the Direction vector
	REAL V_I= REAL($widget('DirectionInput.DirectionFrame.I').value)
	REAL V_J= REAL($widget('DirectionInput.DirectionFrame.J').value)
	REAL V_K= REAL($widget('DirectionInput.DirectionFrame.K').value)
	REAL Calc =0
	IF $V_K == 0 {
		$Calc=90
	} ELSE {
		$Calc=sqrt(($V_I*$V_I)+($V_J*$V_J))
		// PRINT $Calc
		$Calc = Atan($Calc/$V_K)
		IF $Calc > 180 {
			$Calc=$Calc-180
	DIRECTION CANCEL
	DIALOGS MESSAGE ON
	STRING $Result = "Draft angle : " + $round($Calc,2)
	MESSAGE INFO $Result
Sorry works only in release 2017, 2018, 2019  ( function WIDGET available since these releases )
Message 70 of 99
@jjohnybgood wrote:
Hi
Thank you.
Yes )
FUNCTION MAIN() {
If NOT member($session._keys, "DraftAngle") {
	SESSIONPAR BOOL DraftAngle = 0
IF $session.DraftAngle==0 {
	$session.DraftAngle=1
} ELSE {
REAL V_I= 0
REAL V_J= 0
REAL V_K= 0
STRING tmp_file = macro_path(0) + "\_temp.txt"
TRACEFILE OPEN $tmp_file
PRINT FORMVALUE DirectionInput.DirectionFrame.I
PRINT FORMVALUE DirectionInput.DirectionFrame.J
PRINT FORMVALUE DirectionInput.DirectionFrame.K
TRACEFILE CLOSE
// read temp file
FILE OPEN $tmp_file FOR READ AS GetValue
FILE READ $V_I FROM GetValue
FILE READ $V_J FROM GetValue
FILE READ $V_K FROM GetValue
FILE CLOSE GetValue
REAL Calc =0
IF $V_K == 0 {
	$Calc=90
} ELSE {
	// PRINT $Calc
    if $Calc > 180 {
		$Calc=$Calc-180
STRING $Qry = "Draft angle : " + $round($Calc,3)
BOOL Ret = 0
$Ret = QUERY $Qry
IF $Ret  {
	DIRECTION ACCEPT
	$session.DraftAngle=0
} ELSE {
    // Activate Direction measure mode for next value
PS: this macro was adopted for PowerMILL 2016 by user impact  from other PM forum.
Message 71 of 99
johnc4668
@5axes this macro is awesome!  Any way to get it to read for example 7.34 deg instead of 82.66 deg?
Message 72 of 99
5axes
@johnc4668
$Calc=90-$Calc
Message 73 of 99
johnc4668
@5axes heres my macro mod. Im still getting the same result (pardon my macro knowledge!)
Message 74 of 99
iamcdn79
Try this
FUNCTION MAIN() {
	DIALOGS MESSAGE OFF
	BOOL $F_E=FALSE
	REAL $LIMIT_WHILE=0
        REAL $Timer = 0.25
	DO {
		WAIT $Timer
		    DIRECTION CANCEL
			MACRO ABORT
	} WHILE NOT $F_E
	REAL Calc =0
	IF $V_K == 0 {
		$Calc=0
	} ELSE {
		// PRINT $Calc
		IF $Calc > -180 {
			$Calc=90-$Calc
	DIRECTION CANCEL
	DIALOGS MESSAGE ON
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
Message 75 of 99
johnc4668
@iamcdn79 nailed it, thanks! I changed the shade to rainbow and its easier to rotate cad on my computer. Draft shading is jerky with rotating the part. Thanks again, cheers!
Message 76 of 99
danmic7JH66
Playing around with Infoboxes recently I made a macro that lists all selected toolpaths and some parameters for a quick reference and checking over our work. Works like a charm and figured I'd share it here. She gets the job done and makes sure I don't have to flip through a bunch of pages. I dig it, figured others may as well.
// JOB NUMBER AND DETAIL NUMBER VARIABLES
FOREACH $pal IN folder('model') {
if position ($pal.name,"CAM") >= 0 {
FOREACH $mod IN folder('model') {
  STRING Lname = lcase($mod.name)
  if position ($lname,"cam") >= 0 {
    STRING path = pathname(mod)
    STRING base = basename(path)
// MACHINE TOOL VARIABLES
DIALOGS MESSAGE OFF
ACTIVATE MachineTool "Mazak VCU400a"
ACTIVATE MachineTool "Okuma_GENOS_M560_V_No_Guarding"
DIALOGS MESSAGE ON
STRING MACHNAME = ENTITY('machinetool','').name
// INFOBOX TITLE VARIABLES
STRING LIST PARTS = tokens(lname, '-')
STRING JOBNUMBER = UCASE ($PARTS[0])
STRING DETAILNUMBER = UCASE ($PARTS[1])
STRING SESS = UCASE ($PARTS[3])
STRING PROJECTPATH = "S:\aba-agf\" + $JOBNUMBER + "\Session Files\" + $SESS + "\" + $JOBNUMBER + "-" + $DETAILNUMBER + "-" + $SESS + "\ncprograms\"
STRING INFOTITLE = $JOBNUMBER + "-" + $DETAILNUMBER + " TOOLPATH INFO"
// COLOUR VARIABLES
INT LIST RED = {255,0,0}
INT LIST BLACK = {0,0,0}
INT LIST GREEN = {0,255,0}
INT LIST BLUE = {0,0,255}
// TOTAL SIMULATION TIME OF SELECTED TOOLPATHS
REAL SIMTOTE = 0
// BUILDS BASE INFOBOX AND ADDS FILE PATH TO IT
INFOBOX CLEAR FORMAT
INFOBOX STATE "auto_newline" TRUE
INFOBOX NEW $INFOTITLE
INFOBOX STATE "underline" TRUE
INFOBOX STATE "text_colour" $RED
INFOBOX APPEND "MACHINE: "
INFOBOX STATE "underline" FALSE
INFOBOX STATE "text_colour" $BLACK
INFOBOX APPEND $MACHNAME
        BREAK
// STRING VARIABLES
STRING TOOLNAME = ENTITY('tool','').name
STRING STRAT = UCASE (ENTITY('toolpath','').STRATEGY)
STRING TPEDITS = ENTITY('toolpath','').History.Modified
STRING LDSIN1 = $TOOLPATH.Connections.LeadIn[0].Type
STRING LDSIN2 = $TOOLPATH.Connections.LeadIn[1].Type
STRING LDSOUT1 = $TOOLPATH.Connections.LeadOut[0].Type
STRING LDSOUT2 = $TOOLPATH.Connections.LeadOut[1].Type
STRING LNKS = $Toolpath.Connections.Link[0].Type
STRING LNKS2 = $Toolpath.Connections.Link[1].Type
STRING LNKS3 = $Toolpath.Connections.Link[3].Type
STRING TOONUM = ENTITY('toolpath','').tool.number
STRING TOL = ENTITY('toolpath','').TOLERANCE
// REAL VARIABLES
REAL FR = ROUND ($TOOLPATH.FEEDRATE.CUTTING.VALUE, 1)
STRING FRINF = $FR
REAL RPM = ROUND ($TOOLPATH.SPINDLESPEED.VALUE, 1)
STRING RPMINF = $RPM
REAL SIMIND = $TOOLPATH.Statistics.TotalTime
REAL SIMRND = ROUND ($SIMIND, 2)
$SIMTOTE = $SIMTOTE + $SIMRND
STRING THICCINF = ''
STRING THICCINFAXI = ''
STRING SIMRNDINF = $SIMRND + " MINUTES"
STRING LDSININFSND = ''
STRING LDSOUTINFSND = ''
IF $toolpath.UseAxialThickness == 1 {
$THICCINF = $THICC
$THICCINFAXI = $FLTTHICC
} ELSE {
$THICCINF = $THICC
// TOOLPATH NAME
INFOBOX APPEND ""
INFOBOX STATE "bold" TRUE
INFOBOX APPEND $TPNAME
// STRATEGY
INFOBOX STATE "auto_newline" FALSE
INFOBOX STATE "text_colour" $BLUE
INFOBOX APPEND "STRATEGY:"
INFOBOX STATE "bold" FALSE
INFOBOX APPEND " "
INFOBOX APPEND $STRAT
INFOBOX APPEND ""
// TOLERANCE
INFOBOX APPEND "TOLERANCE:"
INFOBOX APPEND " "
INFOBOX APPEND $TOL
INFOBOX APPEND ""
// TOOL
INFOBOX APPEND "TOOL:"
INFOBOX APPEND " "
INFOBOX APPEND $TOOLNAME
INFOBOX APPEND ""
// TOOL NUMBER
IF $TOONUM == "0" {
INFOBOX APPEND "TOOL NUMBER:"
INFOBOX APPEND " "
INFOBOX APPEND "NO TOOL # ASSIGNED"
INFOBOX APPEND ""
	} ELSE {
	INFOBOX APPEND " "
	INFOBOX APPEND $TOONUM
	INFOBOX APPEND ""
// RPM
INFOBOX APPEND "RPM:"
INFOBOX APPEND " "
INFOBOX APPEND $RPMINF
INFOBOX APPEND ""
//FEED
INFOBOX APPEND "FEEDRATE:"
INFOBOX APPEND " "
INFOBOX APPEND $FRINF
INFOBOX APPEND ""
// POINT DISTRIBUTION
IF $TOOLPATH.MaxDistanceBetweenPoints.Active == 1 {
REAL PNTS = ROUND ($TOOLPATH.MaxDistanceBetweenPoints.VALUE, 4)
STRING PNTSINF = $PNTS
INFOBOX APPEND "MAX DISTANCE BETWEEN POINTS:"
INFOBOX APPEND " "
INFOBOX APPEND $PNTSINF
INFOBOX APPEND ""
} ELSE {
// THICKNESS
INFOBOX APPEND "THICKNESS:"
INFOBOX APPEND " "
INFOBOX APPEND $THICCINF
INFOBOX APPEND ""
INFOBOX APPEND "AXIAL THICKNESS:"
INFOBOX APPEND " "
INFOBOX APPEND $THICCINFAXI
INFOBOX APPEND ""
	} ELSE {
	INFOBOX APPEND " "
	INFOBOX APPEND ""
// LEADS IN
IF $TOOLPATH.Connections.LeadIn[1].Type == "none" {
INFOBOX APPEND "LEADS IN:"
INFOBOX APPEND " "
INFOBOX APPEND $LDSIN1
INFOBOX APPEND ""
	} ELSE {
	INFOBOX APPEND "LEAD IN:"
	INFOBOX APPEND " "
	INFOBOX APPEND ""
	INFOBOX APPEND "LEAD IN 2ND CHOICE:"
	INFOBOX APPEND " "
	INFOBOX APPEND $LDSIN2
	INFOBOX APPEND ""
// LEADS OUT
IF $TOOLPATH.Connections.LeadOut[1].Type == "none" {
INFOBOX APPEND "LEAD OUT:"
INFOBOX APPEND " "
INFOBOX APPEND $LDSOUT1
INFOBOX APPEND ""
	} ELSE {
	INFOBOX APPEND " "
	INFOBOX APPEND ""
	INFOBOX APPEND "LEAD OUT 2ND CHOICE:"
	INFOBOX APPEND " "
	INFOBOX APPEND $LDSOUT2
	INFOBOX APPEND ""
// LINKS FIRST
INFOBOX APPEND "LINKS 1ST CHOICE:"
INFOBOX APPEND " "
INFOBOX APPEND $LNKS
INFOBOX APPEND ""
// LINKS SECOND
INFOBOX APPEND "LINKS 2ND CHOICE:"
INFOBOX APPEND " "
INFOBOX APPEND $LNKS2
INFOBOX APPEND ""
// SIMULATION TIME
INFOBOX APPEND "TOOLPATH SIMULATION TIME:"
INFOBOX APPEND " "
INFOBOX APPEND $SIMRNDINF
INFOBOX APPEND " "
// CONVERTS SIM TOTE TO STRING
REAL SIMHRS = $SIMTOTE / 60
REAL SIMRND = ROUND ($SIMHRS, 2)
STRING SIMTOTEINF = $SIMRND + " HRS"
// ADDS TOTAL SIMULATION TIME
INFOBOX APPEND ""
INFOBOX STATE "text_colour" $GREEN
INFOBOX APPEND "TOTAL SIMULATION TIME OF SELECTED TOOLPATHS:"
INFOBOX APPEND " "
INFOBOX APPEND $SIMTOTEINF
INFOBOX APPEND ""
DEACTIVATE MACHINETOOL
Message 77 of 99
Ye。xg
I used PowerMill Ultimate 2019 to run it, but it didn't work.
Message 78 of 99
danmic7JH66
Sorry about that, I had some custom variables in there that only work with our model names and file structure. I reworked it a bit for you, this should do the trick. Try this and let me know how it works and if you like it!
// COLOUR VARIABLES
REAL SIMTOTE = 0
INFOBOX NEW "Programs"
        BREAK
// STRING VARIABLES
// REAL VARIABLES
STRING FRINF = $FR
$THICCINF = $THICC
} ELSE {
$THICCINF = $THICC
// TOOLPATH NAME
INFOBOX APPEND ""
// STRATEGY
INFOBOX APPEND " "
INFOBOX APPEND ""
// TOLERANCE
INFOBOX APPEND " "
INFOBOX APPEND $TOL
INFOBOX APPEND ""
// TOOL
INFOBOX APPEND " "
INFOBOX APPEND ""
// TOOL NUMBER
IF $TOONUM == "0" {
INFOBOX APPEND " "
INFOBOX APPEND ""
	} ELSE {
	INFOBOX APPEND " "
	INFOBOX APPEND ""
// RPM
INFOBOX APPEND " "
INFOBOX APPEND ""
//FEED
INFOBOX APPEND " "
INFOBOX APPEND ""
INFOBOX APPEND " "
INFOBOX APPEND ""
} ELSE {
// THICKNESS
INFOBOX APPEND " "
INFOBOX APPEND ""
INFOBOX APPEND " "
INFOBOX APPEND ""
	} ELSE {
	INFOBOX APPEND " "
	INFOBOX APPEND ""
// LEADS IN
INFOBOX APPEND " "
INFOBOX APPEND ""
	} ELSE {
	INFOBOX APPEND " "
	INFOBOX APPEND ""
	INFOBOX APPEND " "
	INFOBOX APPEND ""
// LEADS OUT
INFOBOX APPEND " "
INFOBOX APPEND ""
	} ELSE {
	INFOBOX APPEND " "
	INFOBOX APPEND ""
	INFOBOX APPEND " "
	INFOBOX APPEND ""
// LINKS FIRST
INFOBOX APPEND " "
INFOBOX APPEND ""
// LINKS SECOND
INFOBOX APPEND " "
INFOBOX APPEND ""
// SIMULATION TIME
INFOBOX APPEND " "
INFOBOX APPEND " "
INFOBOX APPEND ""
INFOBOX APPEND " "
INFOBOX APPEND ""
Message 79 of 99
Ye。xg
Thank you very much for your reply. Now it works very well. Thanks again.
Message 80 of 99
jjohnybgood
Hi danmic7JH66,
Can this be changed to also work from active NC Programme? ie where you have a number of toolpaths in the NC Programme then use macro to display details?
