stock model issue
stock model issue
M_Hennig
Message 1 of 14
stock model issue
M_Hennig
Is PM ever going to fix this stock model issue? There is not a single project I do that the stockmodel does not get corrupt and completely useless. I am tired of constantly exporting and importing the stockmodel I save. Some of my projects have 3 or 4 corrupt stockmodels by the time I am finished.
Replies (13)
Message 2 of 14
iamcdn79
What version of Powermill does this happen in?
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
Message 3 of 14
M_Hennig
2018, All up to date with the latest updates. It has been going on for a few versions. I sent in a project a long time ago, it went nowhere.
Message 4 of 14
M_Hennig
Message 5 of 14
iamcdn79
Try this command and see if it helps, it reverts the stock model calculation to version 2016
PREVIEW stockmodel_shading PREVIOUS
Windows 11 Pro
Message 6 of 14
M_Hennig
Thanks, I will give it a go.. do I do this just once in the beginning of a project?
Message 7 of 14
iamcdn79
I have it in a stock model macro every time I create a new one.
I think you would need it everytime you create a new stock model
Windows 11 Pro
Message 8 of 14
TK.421
@iamcdn79: does that command work in 2017? will it cut down on calculation time, and rest toolpath calc time? I'm running 2017 sp6 and calc times are ridiculous...
the numbers never lie
Message 9 of 14
iamcdn79
@TK.421 yes it will work in 2017 and 2018. I think it is a faster calculation. The reason I needed it was because alot of time it would not show me any rest material after calculation
Windows 11 Pro
Message 10 of 14
TK.421
ok, I will give it a shot!
Message 11 of 14
Pijetro
I've never seen so many duplicated reference toolpaths to the same stock model..In fact, I didn't think it was possible.
Is this the result of the corruption, or just part of your workflow?
Message 12 of 14
M_Hennig
It is the part of the corruption. I will have something go wrong and PM will crash. Then upon opening I get these duplicates, in some instances when you expand the stockmodel window, there will be hundreds of items in there.
Message 13 of 14
samuel.baker
We have had this issue for a while and we are still unsure where it comes from as we are struggling to repeat this issue ourselves, no necessarily the issue that you have but the workflow to get tho this, Could you perhaps let me know more information on this and tell me how you first got to this or is this a recurring issue that happened months ago?
Samuel Baker
Process Specialist
Fusion360 Youtube Channel
Message 14 of 14
M_Hennig
For me, this has been happening for quite some time, at least the last two versions of PM.. It "usually"  happens after a crash and I try to restore all of my project.  However, I did have it happen during a certain sequence of events. I had a bunch of toolpaths applied to my stockmodel and was showing the rest material of a toolpath far up in the stock model tree, then, when that was shown and activated in the explore window, I tried to apply another toolpath, when I did that and calculated it, I got the entire mess in the stock model tree. That is the only one time I actually saw it happen, I never tried to repeat it because once the stock model is messed up, there is nothing you can do with it.
