Macro for Toolist
Macro for Toolist
Hello out there
Im currently using this macro for creating a toollist
Its a macro i've found on this forum, cant remember who made it. but i've made some small changes and everything is good.
But i can't seem to figure out how to get the macro to sort the tools according to the toolnumber, maybe you guys could help me?
Kind regards
Marc Willumsen
Replies (8)
rafael.sansao
@5axes is the developer of this macro. Maybe he'll help you with your request.
Rafael Sansão
OptiNC - www.optinc.tech
5axes
It's me 🙂
 I already change some lines in this macro due to an issue with  FOREACH Tl IN list_nctools(entity('ncprogram', '')) {
because list_nctools returns the ToolId and not the name and if the toolid is diffrent from the tool.name you can have some problems.
The new code is :
// build the expression
STRING $expr = "RootType=='nctoolpath'"
// get the list of tool (sorted in the NCProgram order)
STRING LIST $tl_list = extract(filter(components(entity('ncprogram', $Selected_NCP)), $expr), 'tool.name')
INT Nb=remove_duplicates($tl_list)
/// Liste tous les outils
FOREACH ToolName IN $tl_list {
It's longer but better . And because it's better I think you can do what you want by adding a sort instruction ... in the $Tl_List definition .. I need to check that ..
5axes
Yes, simple .. I've just made the test : Add to the previous code a sort instruction 🙂
STRING LIST $tl_list = extract(sort(filter(components(entity('ncprogram', $Selected_NCP)), $expr) ,'tool.number') , 'tool.name')
So i've tried replacing the code, but im not quite sure where to put it or what to delete
Am i even close or?
Stops at first ENTITY Smiley Sad
And yes i've also experinced the fault with the tool names, mainly because in my country we use "ÆØÅ" and when changed the tool name in the list it still couldnt save the image, but figured it out like 2 weeks ago Smiley Very Happy
STRING $Fold=''
STRING $CFold=''
STRING $Sz="80p"
ENTITY $tp=entity('Tool',$Tl)
        $ToolName = $tp.name
	ENTITY C_Tool = entity('Tool',$ToolName)
	$Fold=dirname(Pathname($C_Tool))
	IF $Fold != $CFold {
		// MESSAGE INFO " $Fold   $CFold "
		$Ligne = "<TR><TD colspan=10 style='background:#4F81BD'><H3>"+ $Fold + "</H3></TD></TR>"
		FILE WRITE $Ligne TO filename
		$CFold=$Fold
	// Depuis les Outils
	$Ligne = "<TR>"
        // Image
        $Ligne = "<TD>"
        $Ligne = '<div align="' + 'center"' + '>'
        // CREATION IMAGE
	$ModiToolName=REPLACE($ToolName," ","_")
	$ModiToolName=REPLACE($ModiToolName,"/","-") // Corrige les nom outils du type  1/4 Endmill
Kind regards
Marc W
5axes
try with this code ..
And for your issue with your langage .. I Just have the solution to add the different REPLACE instruction :
$ModiToolName=REPLACE($ModiToolName,"Æ","AE")
$ModiToolName=REPLACE($ModiToolName,"Ø","O")
$ModiToolName=REPLACE($ModiToolName,"Å","A")
Etc ..
5axes
Oup's   It was the wrong macro Smiley Embarassed     This one is used to create the toollist from a selected NCProgram.
Try with this one
Works like a charm, thank you so much Smiley Very Happy
Best regards
Marc W
