Problem when using conditions
tomanT9U6N
Message 1 of 14
tomanT9U6N
Hello, can someone explain to me why the IF condition cannot be used in this code?
The time.txt file contains only the number 1688722295
Interestingly, if I delete the IF condition in this code, the program will work.
FILE OPEN "time.txt" FOR READ AS "inp"
INT $read_seconds = 0
FILE READ $read_seconds FROM "inp"
FILE CLOSE "inp"
INT $diff = time() - $read_seconds
IF $diff > 60 {
	MESSAGE INFO $diff
Replies (13)
Message 2 of 14
kevin.hammond3WX4X
Try this, enclose the condition to be checked.
FILE CLOSE "inp"
IF ($diff > 60) {
MESSAGE INFO $diff
Message 3 of 14
tomanT9U6N
I've tried and still get the error: unsupported element or command
Message 4 of 14
kevin.hammond3WX4X
Works for me, after i put the full path to time.txt in
i.e
FILE OPEN "C:\Users\KevinHammond\Desktop\time.txt" FOR READ AS "inp"
FILE CLOSE "inp"
IF ($diff > 60) {
MESSAGE INFO $diff
Message 5 of 14
tomanT9U6N
Thank you then it is not a bug in the code, but in my computer.
Message 6 of 14
Sean571
Make sure the file is not located in folder that doesn't have read/write access like in "Program Files" or something.
Sean Wroblewski
Applications Engineer
Message 7 of 14
old_snickers
I'm really confused now. Why does this work with the quotes at "inp" and another recently issue did not?
Message 8 of 14
tomanT9U6N
Writing data to the file and reading data from the file works. The macro error occurs when I insert an arbitrary condition in the code. 🫤
Message 9 of 14
lokesh.kalia
@old_snickers Hi. You don't actually need the double quotes around inp, given that this is a single word without spaces.
See the extract from the Macro Programming Guide below, which shows an example of defining so-called file handles without any quotes:
You can find the latest version of the Macro Programming Guide here: https://www.autodesk.com/support/technical/article/caas/tsarticles/ts/26zXUqtRe1Tur1KdK1pctn.html
(scroll down towards the bottom of the page).
@tomanT9U6N Hi. Unfortunately, I also can't reproduce your error. You might try using the 'macro debugger', it might give a clue to what is going wrong.
You invoke this by:
macro debug <path-to-macro-file>
I hope that will help.
Lokesh Kalia
Senior Manager, Software Development
Message 10 of 14
kevin.hammond3WX4X
I more item to check....
Is the macro being run from from a trusted files or trusted directory, i have seen macros questioned from time to time usually if they are stored on a network drive. check options as below.
Hope you get sorted 🙂
Message 11 of 14
tomanT9U6N
When I try macro debug, the whole code is displayed in one line. That's weird.
Message 12 of 14
tomanT9U6N
Thank you all for your help, but the problem seems to be with my PC.
Message 13 of 14
kevin.hammond3WX4X
1 last thing based on your last response.
what text editor are you using, i am wondering whether when you hit enter to go to the next line whether you are getting a carriage return line feed command?
I use notedpad++ but windows text editor will do, i would not use wordpad as it can give spurious results.
I have switched on these characters using..View...Show symbols
If you do not have these characters it would cause the whole macro to appear on one line
Message 14 of 14
tomanT9U6N
You are an absolute legend! I had the line ordering set to CR. After switching to CRLF the macro works!
Thank you very much 😊
