Cannot insert variables into file
tomanT9U6N
tomanT9U6N
Hello, I can open and close the text file datum.txt, but I can't insert anything into it. Each time I get the error: wrong command on the line FILE WRITE $text TO "out"
Do you know where I have the error?
STRING $text = "test"
FILE OPEN "c:\PowerMill\datum.txt" FOR APPEND AS "out"
FILE CLOSE "out"
old_snickers
It has to be something like this:
FILE OPEN "anypath\anyfile.txt" FOR WRITE AS out
FILE WRITE $text to out
FILE CLOSE out
This worked for me.
I don't know the "append"-command, but mainly I think the quotes at "out" are wrong.
Sean571
APPEND works just as well as WRITE, but the problem again is the quotes. so I believe that this should work:
FILE OPEN "c:\PowerMill\datum.txt" FOR APPEND AS out
FILE WRITE $text TO out
FILE CLOSE out
@old_snickers  Appending just adds to the text file whereas writing will override anything in the text file.
Sean Wroblewski
Applications Engineer
