I've run into this issue previously, and asked the question on the old forum, but never really got anywhere. A link to the old post is below
Old Delcam User Forum post
Anyway, the problem.
I have a number of PlugIns running successfully in PowerMILL, all of them are built using vb.NET, however, if I install a PlugIn built using C# I end up with a graphics issue in the plug in window, see images below
The first picture is a plug in pane open normally, everything is ok
The second picture is what happens to the pane when the plug in of a different build type is opened
In the past, all my vb.NET panes were working well until I installed the Text Creator plugin from Delcam, at that point only Text Creator worked and all the others had the same problem I see now. If I uninstalled the Text Creator everything went back to normal.
Currently, all vb.NET built plug in panes expand and collapse normally, no problem. The single C# plug in pane has this graphics issue. But in the current situation when I uninstall all the vb.NET plugins, I still have the same problem with the C# plug in.
Has anyone else had this problem? If so, how did you resolve it?
Is there a PowerMILL apps guru reading this who could help me out?
Many thanks in advance
