PowerMILL Excel SetupSheet plugin
michael.grenier4GVTU
Autodesk Autodesk
Message 1 of 151
Hi Everyone,
I've been working on another plugin last year that was just publicly released.  This one will let you create an excel template to export your setupsheets.  It gives you a bit more flexibility than the current setupsheet we have in PowerMILL.  On top of that, since the source code is available you can do whatever you want with it.  The plugin include a folder of sample files and some documentation as to how to use it.
I'm joining the pdf I made to give you an idea of what is available but also what can be done with it.
https://github.com/Autodesk/powermill-api-examples/tree/master/addin-excel-setup-sheet
Enjoy!
Michael
Michael Grenier
Senior Solution Engineer
Replies (150)
Message 141 of 151
nathanANTQX
@jjohnybgood2 Attached is our template that has been quite useful, and it has some hidden columns with some added in for for clamping etc, with data validation, for the drop down lists in the clamping information, as well as machine numbers etc....
Message 142 of 151
jjohnybgood2
@nathanANTQX
Do you have a modified Installer that will print out both tool list and NC Programmes on same sheet? Thank you.
Message 143 of 151
You do not need another installer for that, you need to change the setupsheet template in the plugin options. I attached a template that does that on my previous post.
Michael
Michael Grenier
Message 144 of 151
jjohnybgood2
Thank you. I have it working now.
Message 145 of 151
jjohnybgood2
Can you help me to alter it so as it just lists the tool once for each different tool and the NC programmes with it. The template you just supplied lists every tool for every path where as I just want the tool list? Thank you
Message 146 of 151
There should be two tabs at the bottom in Excel, one for the toolpath list, and one for the tool list only.
Also, in the install directory, there is a pdf file that goes over pretty much everything there is to know as far as setting up templates, you can take a look there.
Do you see that?
Michael Grenier
Message 147 of 151
jjohnybgood2
OK I will have a look. Thank you
Message 148 of 151
nathanANTQX
Good Morning Michael
Thank you so much for the update, I am going to install the latest update today. I appreciate all the effort put in to this plugin. I have a question, if its possible to add, we often put text blocks into our programs with instructions, could that be added as a "fake" toolpath and used with the {toolpath.name} so it can be added within the toolpath list. as seen below?
Could the names of the Text blocks be Added into the setup sheet as indicated with the red notations.
There is no Rush or urgency, If you have free time and are able to, please can it be added.
Powermill NC file with all the toolpaths and text blocks:       |           Setup Sheet output:
Kind Regards Nathan
Message 149 of 151
@nathanANTQX , quick update I thought might be interesting for you.
Michael Grenier
Message 150 of 151
jjohnybgood2
Hi, I like this template LATEST 2024 - TEMPLATE but would like to add some more columns to the lower section.
Can anyone add the following columns to the template and attach it here for me to download?
These are what I want added if possible?
Toolpath Type
Plunge
Feed
RPM
Coolant
Air
Hope someone can help. I'm not too familiar with excel so not sure how to go about doing it myself.
Thank you
Message 151 of 151
jjohnybgood2
Toolpath Type
Plunge
Feed
RPM
Coolant
Air
Thank you
