- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello all, I've been trying to create some Netfabb Strategies in the Additive module, using a simple part, a rectangle with curved borders (30 mm radius), a really easy part, just to try some strategies.
The thing is that THERE IS NO WAY to create a strategies that make CURVES in the BORDES, NO WAY, I changed and tried all the possible parameters in all the possible strategies, even changing the tolerances options for the whole program... there is no change in the borders. I show a image here:
Can someone please tell me how to create a perfect contour that addapts to the real part geometry? I just want a solid pattern with one or two perfect contour paths, actually it should'nt be that hard to do.
