PM2027 Model Patch Selection Issue
evo80
Message 1 of 23
evo80
Is anyone having problems with model patch selections in PM2027?
PM2026 no issues.
Replies (22)
Message 2 of 23
iamcdn79
Try one of these 2 possible solutions, depending on your graphics card
https://forums.autodesk.com/t5/powermill-forum/selection-issues-2026/m-p/13962590
If that doesn't work, make sure your graphics card driver is up to date
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
Message 3 of 23
icse
I think you found a bug
Message 4 of 23
Benjamin.Br
Hello @evo80. I'm sorry you're having issues with PowerMill 2027. Can you please confirm that PowerMill 2026 and PowerMill 2027 are running on the same PC? Are you willing to share a model that shows the problem please?
Benjamin Brereton
Director, Engineering
Message 5 of 23
evo80
@Benjamin.Br
Yes, both PM2026 and PM2027 are running on the same PC.
The zip file contains a model from the PM2027 examples folder, it's not one particular model but every model I've tested.
Message 6 of 23
iamcdn79
Did you try my recommendations? I don't have any issue here
Windows 11 Pro
Message 7 of 23
evo80
I updated the nvidia graphics card drivers and the same thing with selecting patches in PM2027.
Message 8 of 23
iamcdn79
Are you on Windows 10 or 11?
Windows 11 Pro
Message 9 of 23
evo80
Message 10 of 23
cc-ye
这是他们公司现在的常规操作了。😂
Translation:
This has become their company's routine operation now.
 @cc-ye - moderator has edited this post to provide for translation. Please use a translator to post in English.
Message 11 of 23
iamcdn79
To rule out it's a mouse problem, can you try a co-workers mouse?
Windows 11 Pro
Message 12 of 23
evo80
So I installed PM2027 on another PC (PC2) and low and behold no issues with patch selection! I checked the graphic card settings and both PCs have identical settings yet the first PC (PC1) is still misbehaving, any ideas why? And I swapped the mouse from PC2 to PC1 with no change.
Message 13 of 23
iamcdn79
Is PC1 a Windows Insider Program of Windows at all?
It sounds like there is a setting turned on PC1 that the new version of Powermill doesn't like
Windows 11 Pro
Message 14 of 23
evo80
I don't understand what you mean by this.
Message 15 of 23
evo80
I'll try a clean install, see if that helps
Message 16 of 23
iamcdn79
The Windows Insider Program is an open software testing program that lets users with a valid Windows license preview pre-release builds of the operating system. It allows enthusiasts, developers, and IT professionals to test experimental features and provide feedback.
I was part of it and I noticed I had an issue with a macro that worked and then a Windows update broke. Also my backup software got messed up. When I finally left the pgm the backup worked again.
Windows 11 Pro
Message 17 of 23
evo80
Is there a trick to uninstalling PM2027?
It's not showing in the installed Apps in Add and Remove Programs??
Message 18 of 23
iamcdn79
Look for Powermill 2027 not Autodesk Powermill 2027
Windows 11 Pro
Message 19 of 23
evo80
Wow, you'd think Autodesk would keep the naming convention the same as previous releases wouldn't you, anyhow thanks I found it!
Message 20 of 23
evo80
Hmmm, did a clean install with the same issue. Maybe I'll just stick with PM2026, it's not like Autodesk are making anymore major enhancements to this software.
