PowerMill Forum
Welcome to Autodesk’s PowerMill Forums. Share your knowledge, ask questions, and explore popular PowerMill topics.
Please add a stop generation button
16 REPLIES 16
Message 1 of 17
cheidenfelder
1316 Views, 16 Replies
Can you please add a stop generation button? There is nothing worse than losing work because the generating fillets gets stuck at 5% and you have to crash out. Also stop inheriting this generate fillets on following operations.
16 REPLIES 16
Message 2 of 17
Sean571
in reply to: cheidenfelder
There already is one while calculating. It's the red X to the left of the progress bar or also pressing the Escape key runs the command to quit. It just doesn't always work the way you'd like it to, or stop calculating as fast as you'd like.
Sean Wroblewski
Applications Engineer
Message 3 of 17
cheidenfelder
in reply to: Sean571
I know about the "X", that only works on some paths. It will not stop the 3D fillet calculation.
Message 4 of 17
glen_h
@cheidenfelder
I agree...the stop button is rendered mostly useless when 3d arc fitting is calculating. And I cannot stand it when the 3d arc fitting is inherited from one toolpath to another...some times I will forget to turn it off, then once you get down to some tiny cutters...Powermill just goes for a permanent snooze...so up comes Task Manager! Been burned countless times. (same deal with corner finishing)
Big thanks to all who contribute!
My opinions are my own and are not intended to reflect yours.
Message 5 of 17
evo80
When I get in this situation I bang away at the Pause/Break key, this quite often does a much better job than the X at the progress bar.
Message 6 of 17
I will give the old pause/break key a good try next time it happens. I will let you know if it worked.
Message 7 of 17
M_Hennig
The pause-break key does nothing for me, although I do bang on the escape key, sometimes it works, but most of the time a message pops up that says "break hit" and the computer just hangs up, sometimes for a few seconds, sometimes minutes, and sometimes forever, and I have to kill the process in the task manager. The more intense the toolpath, the less likely you can kill it mid calculation.
Message 8 of 17
evo80
in reply to: M_Hennig
@M_Hennig , I agree totally, the key to a successful calculation stoppage is to catch it quick
Message 9 of 17
Same here, as @M_Hennig said, we bang Escape until something happens, because sometimes one tap is not enough. But, again ocasionally we have to kill complete PMILL process.
Message 10 of 17
iamcdn79
in reply to: glen_h
@glen_h wrote:
@cheidenfelder
What I have done in this situation is I created my own most used Finishing toolpaths and created a macro inside the ribbon that calls the template with 3D fillet turned off every time it is used.
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
Message 11 of 17
glen_h
in reply to: iamcdn79
@iamcdn79
Excellent workaround!
Message 12 of 17
When you start a new tool path the macro runs automatically, or you start a new toolpath than fire the macro?
Message 13 of 17
iamcdn79
Make a macro that opens the toolpath form with fillet corners turned off by default. Then add the macro to your Ribbon bar.
Here is a sample for a constant-z toolpath
IMPORT TEMPLATE ENTITY TOOLPATH TMPLTSELECTORGUI "Finishing/Constant-Z-Finishing.002.ptf"
EDIT PAR 'CornerRadius.Active' '0'
Windows 11 Pro
Message 14 of 17
I see what you are doing, thanks. It is pathetic we have to constantly come up with work arounds to get the software to work correctly. They never fix anything.
Message 15 of 17
Cant this be achieved by adding all this to the PMuser.mac, during startup?
Message 16 of 17
The problem is it will inherit from another path that you had 2d fillets, for some reason it will turn on 3d fillets on if the new path doesn't have 2d fillet.
Message 17 of 17
hmmm, seen interesting issues on redistribute- arcs and filtering
