Please add a stop generation button
cheidenfelder
cheidenfelder
Can you please add a stop generation button? There is nothing worse than losing work because the generating fillets gets stuck at 5% and you have to crash out. Also stop inheriting this generate fillets on following operations.
Replies (16)
Sean571
There already is one while calculating. It's the red X to the left of the progress bar or also pressing the Escape key runs the command to quit. It just doesn't always work the way you'd like it to, or stop calculating as fast as you'd like.
Sean Wroblewski
Applications Engineer
cheidenfelder
I know about the "X", that only works on some paths. It will not stop the 3D fillet calculation.
glen_h
@cheidenfelder
I agree...the stop button is rendered mostly useless when 3d arc fitting is calculating. And I cannot stand it when the 3d arc fitting is inherited from one toolpath to another...some times I will forget to turn it off, then once you get down to some tiny cutters...Powermill just goes for a permanent snooze...so up comes Task Manager! Been burned countless times. (same deal with corner finishing)
Big thanks to all who contribute!
My opinions are my own and are not intended to reflect yours.
evo80
When I get in this situation I bang away at the Pause/Break key, this quite often does a much better job than the X at the progress bar.
cheidenfelder
I will give the old pause/break key a good try next time it happens. I will let you know if it worked.
M_Hennig
The pause-break key does nothing for me, although I do bang on the escape key, sometimes it works, but most of the time a message pops up that says "break hit" and the computer just hangs up, sometimes for a few seconds, sometimes minutes, and sometimes forever, and I have to kill the process in the task manager. The more intense the toolpath, the less likely you can kill it mid calculation.
evo80
@M_Hennig , I agree totally, the key to a successful calculation stoppage is to catch it quick
armin.bosnjakN3JE3
Same here, as @M_Hennig said, we bang Escape until something happens, because sometimes one tap is not enough. But, again ocasionally we have to kill complete PMILL process.
iamcdn79
@glen_h wrote:
@cheidenfelder
What I have done in this situation is I created my own most used Finishing toolpaths and created a macro inside the ribbon that calls the template with 3D fillet turned off every time it is used.
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
glen_h
@iamcdn79
Excellent workaround!
cheidenfelder
When you start a new tool path the macro runs automatically, or you start a new toolpath than fire the macro?
iamcdn79
Make a macro that opens the toolpath form with fillet corners turned off by default. Then add the macro to your Ribbon bar.
Here is a sample for a constant-z toolpath
IMPORT TEMPLATE ENTITY TOOLPATH TMPLTSELECTORGUI "Finishing/Constant-Z-Finishing.002.ptf"
EDIT PAR 'CornerRadius.Active' '0'
Windows 11 Pro
cheidenfelder
I see what you are doing, thanks. It is pathetic we have to constantly come up with work arounds to get the software to work correctly. They never fix anything.
todd.murphy8YH67
Cant this be achieved by adding all this to the PMuser.mac, during startup?
cheidenfelder
The problem is it will inherit from another path that you had 2d fillets, for some reason it will turn on 3d fillets on if the new path doesn't have 2d fillet.
todd.murphy8YH67
hmmm, seen interesting issues on redistribute- arcs and filtering
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
