MORE TASK BAR USER DEFINED FIELDS
kmarkopouliotis
Message 1 of 18
kmarkopouliotis
DOES ANYONE HAVE AN IDEA HOW MORE USER DEFINED FIELDS MIGHT BE ADDED ?
THANK YOU.
Replies (17)
Message 2 of 18
iamcdn79
Until you have the ability to add more user defined fields you can use the Quick access toolbar. Its a little more powerful where you can add macros and commands as well as expressions.
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
Message 3 of 18
kmarkopouliotis
Thank you very much Andre,
this helped me a lot.
i would like to have your support on some issues that i'm facing in holemaking whenever you are avaliable.
Thank you once more
Message 4 of 18
iamcdn79
Sure no problem
Windows 11 Pro
Message 5 of 18
danmic7JH66
One issue I have with the expression fields is they don't always update for me right away. There are many times where the value that's displayed is an old value. Overall it's a super useful tool for me being able to display different project parameters for a quick visual reference, just wish it refreshed a little faster.
Message 6 of 18
kmarkopouliotis
Hi ANDRE, I'M TRYING TO CREATE AN EXPRESSION FIELD IN ORDER TO SEE ACTIVE HOLE'S DEPTH BUT I RECEIVE AN ERROR. WHAT AM I DOING WRONG ??? THANK YOU.
Message 7 of 18
iamcdn79
I have the same issue on my end as well
Windows 11 Pro
Message 8 of 18
iamcdn79
Its not working for me as well. Not sure why it has {oldfeature}
Windows 11 Pro
Message 9 of 18
evo80
Message 10 of 18
iamcdn79
Do you mean your own customized text? Just add a ' and whatever you write in between gets added
Windows 11 Pro
Message 11 of 18
evo80
Thanks Mate,
I'm assuming the 3 is for decimal places?
Message 12 of 18
iamcdn79
Yup
Windows 11 Pro
Message 13 of 18
O.C.
Is there a way to add the Tool name to either Quick access tool bar or the user defined fiels in the status bar?
Message 14 of 18
p.valente
Can you please can share with us all of that expressions ? The formula.
Thanks in advance.
Message 15 of 18
Dkal7
Hello there.
Very nice thread.
Question: Wha's the expression to show the active tool?
Thank!
Message 16 of 18
glaubergimenez
Hi! try $tool.name to see if it works for you. 👈 @Dkal7
Message 17 of 18
Dkal7
Works perfect thank.
Is there a way to increase the field so the whole name can fit?
Message 18 of 18
glaubergimenez
unfortunately I don't know, but it would be good if the user needs it, maybe someone from the forum with more experience can answer for us.
