Macro to create NC code
newbie123abc
Message 1 of 29
newbie123abc
Hi everybody,
I usually create NC code for active toolpath by right click on it and then choose command "Create Individual NC Program". Now, I would like to make a macro to do this. This is my macro (active toolpath is 6000):
EXPLORER SELECT Toolpath "Toolpath\6000" NEW
CREATE NCPROGRAM "6000" EDIT NCPROGRAM "6000" APPEND TOOLPATH "6000" DEACTIVATE NCPROGRAM
I would like to active another toolpath like 6001 and run this macro for creating NC code file with name 6001, could you please fix it for me ?
Thank you very much !
Replies (28)
Message 2 of 29
NanchenO
@newbie123abc,
It is not exactly what you need, but you could alter this one:
EXPLORER SELECT FOLDER "NCProgram" NEW
DEACTIVATE NCProgram
ENTITY LIST $ents = INPUT ENTITY MULTIPLE ncprogram "Select NC programs"
FOREACH $nc IN $ents {
	ACTIVATE NCProgram $nc.Name
	EDIT NCPROGRAM SELECTED FOLDER "P:\bla\bla\"\r
	NCSELECTED APPLY\r
// Put your "rename" / append functionality here
	EDIT NCPROGRAM SELECTED FILEMASK  P:\bla\bla\{ncprogram}.MPF
	NCSELECTED APPLY\r
	EDIT NCPROGRAM SELECTED TAPEOPTIONS "P:\Powermill\Post-pro\YOUR_PP.pmoptz"\r
	NCSELECTED ACCEPT\r
	KEEP NCPROGRAM SELECTED\r
	YES\n
It should be a good starting base...
Olivier
Message 3 of 29
GlennM.MCAM
You can use the build in function for this without macro.
Select your toolpaths you want to make a nc program off, right click and select "create individual nc programs".
Glenn
Intel i7 4790 @ 3.60GHz -16GB RAM - Nvidia Quadro K620 - 250GB SSD - Win 7 Pro x64 SP1
PowerMILL Premium 2019.1 - PowerINSPECT Ultimate OMV 2017 SP6
Message 4 of 29
GlennM.MCAM
But offcourse, @NanchenO gives a great solution with much more possibilities Smiley Wink
Message 5 of 29
newbie123abc
Hi @GlennM.MCAM@NanchenO
I'm beginner and I'm trying to learn macro by recording. Could you please help me to make a simple macro just create NC code for any active toolpath instead of right click on active toolpath and choose "Create Individual NC Program".
Message 6 of 29
kukelyk
Try this:
CREATE NCPROGRAM ; ACTIVATE NCPROGRAM # EDIT NCPROGRAM ; APPEND TOOLPATH ; DEACTIVATE NCPROGRAM
Message 7 of 29
newbie123abc
Hi @kukelyk,
Thank you very much, it work good. But the name of NC code file is not match with toolpath. Could you please fix for me ( for detail, please see attached photo)
Message 8 of 29
kukelyk
IF NOT ENTITY_EXISTS('NCPROGRAM', $toolpath.name) {
CREATE NCPROGRAM $toolpath.name ACTIVATE NCPROGRAM # EDIT NCPROGRAM ; APPEND TOOLPATH ; DEACTIVATE NCPROGRAM
} ELSE {
STRING msg = "Ncprogram '" +$toolpath.name + "' already exists"
MESSAGE INFO $msg
Message 9 of 29
newbie123abc
Hi @kukelyk
Great ! This is a macro I need. Thank you very much !
Message 10 of 29
newbie123abc
Hi @kukelyk,
Can I have one more question ? With your macro, I inserted some codes to make code file like picture which was attached. It is right with active toolpath 6000 and is not right with another active toolpath. Could you please fix it so that can run with any active toolpath. Thank you very much !
Here is my macro:
} ELSE {
MESSAGE INFO $msg
EXPLORER SELECT NCProgram "NCProgram\6000" NEW
EDIT NCPROGRAM "6000" QUIT FORM NCTOOLPATH
EDIT NCPROGRAM "6000" FILENAME "C:\Users\AESI-CAM3\Desktop\New project\test\sample\ncprograms\6000.H"
EDIT NCPROGRAM "6000" NUMBER "6000"
EDIT NCPROGRAM '6000' ITEM 0 COMPONENT 0 FIXTUREOFFSET "1"
NCTOOLPATH ACCEPT FORM ACCEPT NCTOOLPATHLIST FORM ACCEPT NCTOOLLIST
Message 11 of 29
kukelyk
	STRING ncp_path =  "C:\Users\AESI-CAM3\Desktop\New project\test\sample\ncprograms\"+ $toolpath.name + ".H"
	EDIT NCPROGRAM ; FILENAME $ncp_path
	INT k = INT($toolpath.name) //You should add some comparison, if the toolpath name can be converted into int, or not..
	EDIT NCPROGRAM ; NUMBER $k
	EDIT NCPROGRAM ; ITEM 0 COMPONENT 0 FIXTUREOFFSET "1"
} ELSE {
	MESSAGE INFO $msg
Message 12 of 29
newbie123abc
Hi @kukelyk,
Thank you so much. It works very well.
Message 13 of 29
newbie123abc
Hi @kukelyk,
Sorry to bother you again, but could you please help me this issue ?
I had a macro that will export toolpath name, tool name and toolpath length to excel file. This is the macro:
// Macro to export NC data to Excel
// Open File
FILE OPEN "c:\temp\NC.csv" FOR WRITE AS "output"
// Cycle through the NC programs
FOREACH ncp IN folder('NCProgram') {
	// Create an empty list
	STRING List names = {}
	// Output NC Program name
	STRING nome = "NC Program:," + ncp.Name
	FILE WRITE $nome TO "output"
	// Output Header for Toolpath data
	STRING header = "Toolpath Name, Tool Name, Toolpath Length"
	FILE WRITE $header TO "output"
	// loop over the components in the nc program
	FOREACH item IN components(ncp) {
		// Check that it is a toolpath
		IF item.RootType == 'nctoolpath' {
			// Use MEMBER to check that we have not seen this name before
			IF NOT member(names, item.Name) {
				// Add name to list
				bool ok = add_last(names, item.Name)
				// Output data for current toolpath
				STRING line = item.Name + "," + item.Toolname.value + "," + string(item.Length.value)
				FILE WRITE $line TO "output"
			} else {
	// Write an empty line
	STRING empty_line = " "
	FILE WRITE $empty_line TO "output"
// Close File
FILE CLOSE "output"
Is there any way to get time of toolpath instead of toolpath length ? Here is the value which I want to export to excel file:
Message 14 of 29
kukelyk
Try this:
REAL Time = $entity('toolpath',$item).statistics.LeadsandLinks.Times.plunge + $entity('toolpath',$item).statistics.LeadsandLinks.Times.ramp+ $entity('toolpath',$item).statistics.LeadsandLinks.Times.rapid
$Time = $Time + $entity('toolpath',$item).statistics.LeadsandLinks.Times.others + $entity('toolpath',$item).statistics.cuttingmoves.Times.arcs + $entity('toolpath',$item).statistics.cuttingmoves.Times.linear
STRING Timestring =  ''
STRING hours = STRING(INT($Time/60))
IF INT($hours) < 10 {
	$hours = '0' + $hours
STRING mins = STRING(INT($Time%60))
IF INT($mins) < 10 {
	$mins = '0' + $mins
STRING secs = STRING(INT((($Time-INT($Time%60))*60)))
IF INT($secs) < 10 {
	$secs = '0' + $secs
$Timestring =  $hours + ":" + $mins + ":" + $secs
Message 15 of 29
newbie123abc
Hi @kukelyk
Thank you for you help, but it doesn't match with my expectation. I had a NC program like this:
And when I run my macro above, I will have a file in C drive like
Can I have the macro so that when I run it, I can get toolpath time instead of toolpath length like this: ( the time will be copied at the row where i highlighted at the photo above)
Please help me if you have any solution. Thank you very much !
Message 16 of 29
kukelyk
 Try to continue this:
REAL sumtime = 0
FOREACH ncp IN FOLDER('ncprogram') {
	REAL ncptime = 0
	FOREACH $tp IN COMPONENTS($entity('ncprogram',$ncp)) {
		IF $tp.RootType == 'nctoolpath' {
			REAL Time = 0
			$Time = $entity('toolpath',$tp.name).statistics.LeadsandLinks.Times.plunge + ...
			$ncptime = $ncptime + $Time
			$sumtime = $sumtime + $Time
Message 17 of 29
newbie123abc
Hi @kukelyk,
I'm a beginner so I don't know how to use your macro. Could you please write full macro for me ? I tried to edit my macro like this but it didn't work:
// Open File
STRING header = "Toolpath Name, Tool Name, Toolpath Time"
// Add name to list
STRING line = item.Name + "," + item.Toolname.value + "," + string(item.Statistics.Time.value)
} else {
// Close File
FILE CLOSE "output"
I changed my macro at the red cirlce.
Message 18 of 29
kukelyk
Try this:
// Open File
REAL sumtime = 0
	REAL ncptime = 0
			STRING tpTime =  ''
				$mins = '0' + $mins
				$secs = '0' + $secs
			$tpTime =  $hours + ":" + $mins + ":" + $secs
				// Add name to list
				STRING line = item.Name + "," + item.Toolname.value + "," + $tpTime
// Close File
FILE CLOSE "output"
Message 19 of 29
newbie123abc
Hi @kukelyk,
Thank you for your full macro. I tried to run it but there is a mistake like this. Could you have any solution to solve ?
Message 20 of 29
kukelyk
Hope this will work :
// Open File
REAL sumtime = 0
	REAL ncptime = 0
			REAL Time = $entity('toolpath',$item.name).statistics.LeadsandLinks.Times.plunge + $entity('toolpath',$item.name).statistics.LeadsandLinks.Times.ramp+ $entity('toolpath',$item.name).statistics.LeadsandLinks.Times.rapid
			$Time = $Time + $entity('toolpath',$item.name).statistics.LeadsandLinks.Times.others + $entity('toolpath',$item.name).statistics.cuttingmoves.Times.arcs + $entity('toolpath',$item.name).statistics.cuttingmoves.Times.linear
			STRING tpTime =  ''
				$mins = '0' + $mins
				$secs = '0' + $secs
				// Add name to list
// Close File
FILE CLOSE "output"
