Macro to check names of toolpath against the tool used
Alir3za
Alir3za
Hey all.
I need a macro that checks the names of all toolpaths against the tool used in them and reports any mismatches with a warning or something similar. For example, if a toolpath is named "r4" but the tool used in it is "r3," it should report that.
 Thank in advance for your help.
nguyenthinhvt95
Try this code :
String  msg = ""
FOREACH tp IN folder('toolpath') {
if $tp.name != $tp.tool.name {
$msg = $msg +  crlf + $tp.name
if $msg != "" {
$msg = "The list of toolpaths which do not match the tool:" + $msg
message error $msg
Alir3za
When I set the correct values still gives me the error which it shouldn't
nguyenthinhvt95
could you please take some picture of the error you get?
