featureset creation without chemfer
karan30782
Message 1 of 10
karan30782
HI ! Everyone,
Can anyone help me with the following macro.
Everytime when I run the macro it stops with an error.
FUNCTION Main () {
FORM BLOCK
EDIT BLOCK RESET
BLOCK ACCEPT
EDIT MODEL ALL SELECT SURFACE
EDIT FEATURECREATE TYPE HOLE EDIT FEATURECREATE CIRCULAR ON EDIT FEATURECREATE FILTER HOLES EDIT FEATURECREATE TOPDEFINE ABSOLUTE EDIT FEATURECREATE BOTTOMDEFINE ABSOLUTE FORM CANCEL FEATURE FORM CREATEHOLE
EDIT OPTIONS CLOSETOL "0.01"
EDIT FEATURECREATE HOLES FIXED ON
EDIT FEATURECREATE HOLES COMPOUND OFF
EDIT FEATURECREATE HOLES DIRECTION DOWN
EDIT FEATURECREATE MULTAX OFF
EDIT FEATURECREATE HOLES OPEN ON
EDIT FEATURECREATE MIN_ARC_ANGLE "175"
EDIT FEATURECREATE HOLES CAPPED EXCLUDE
EDIT FEATURECREATE CREATEHOLES
FORM CANCEL CREATEHOLE
STRING $fset = INPUT ENTITY FEATURESET "Select FeatureSet"
CALL RemoveChamfers($fset)
FUNCTION RemoveChamfers (STRING CurrentFeatureset) {
// Removes Chamfers from holes, and extends the next featureset depth.
INT subNum = 0
INT comp = 0
INT TestUnsorted = 0
BOOL RemovedChamfer = 0
STRING ActiveFS = $CurrentFeatureset
STRING NEWActiveFS = $ActiveFS + "_NO_CHAMFERS"
STRING NEXTActiveFS = ""
STRING $Testing = 0
IF entity_exists('FEATURESET',$NEWActiveFS) {
	DELETE FEATURESET $NEWActiveFS
DEACTIVATE FEATURESET
Activate FeatureSet $ActiveFS
$NEXTActiveFS = new_entity_name('FEATURESET',$ActiveFS)
COPY FEATURESET $ActiveFS
RENAME Featureset $NEXTActiveFS $NEWActiveFS
Activate FeatureSet $NEWActiveFS
INT SSubIndex = 0
	FOREACH feat IN components (ENTITY ('Featureset',$NEWActiveFS)) {
		IF feat.type == 'hole' {
			$SSubIndex = 0
			IF feat.num_items > 1 {
				FOREACH sub IN components(feat) {
					$SSubIndex = $SSubIndex + 1
					IF ((sub.Draft < 50) AND (sub.Draft > 40)) OR ((sub.Draft > -50) AND (sub.Draft < -40)) {
						IF $SSubIndex < 2 {
							$RemovedChamfer = 1
							INT subNum2 = $subNum + 1
							REAL depthPrevComp = 0
							ACTIVATE FEATURESET $NEWActiveFS
							EDIT FEATURESET $NEWActiveFS SELECT $feat.name
							IF subNum > 0 {
								$depthPrevComp = abs(components(components(entity('Featureset', $NEWActiveFS))[$comp])[$subNum-1].Depth)
							IF subNum2 < feat.num_items {
								REAL depth = abs(components(components(entity('Featureset', $NEWActiveFS))[$comp])[$subNum2].Depth) - $depthPrevComp
								EDIT FEATURESET ; FEATURE SELECTION $subNum2
								EDIT FEATURESET ; FEATURE SELECTED COMPONENT SELECTED DEPTH $depth
							IF subNum2 == feat.num_items {
								$subNum2 = $subNum2 - $subNum
								REAL depth = 0
								IF feat.num_items > 2 {
									$depth = abs(components(components(entity('Featureset', $NEWActiveFS))[$comp])[$subNum].Depth) - abs(components(components(entity('Featureset', $NEWActiveFS))[$comp])[0].Depth)
								} ELSE {
									$subNum2 = $subNum2 - 1
							EDIT FEATURESET ; FEATURE DELETE
							EDIT FEATURESET $NEWActiveFS DESELECT $feat.name
							$subNum = $subNum - 1
					$subNum = $subNum + 1
				$subNum = 0
		$comp = $comp + 1
			$Testing = "Feature Dia = "+$feat.Diameter
			PRINT $Testing
	$comp = 0
	// Delete the Featureset if NO chamfers were found.
$TestUnsorted = POSITION($NEWActiveFS,"UNSORTED")
	IF $RemovedChamfer == 0 {
	} ELSEIF $TestUnsorted == -1 {
		CALL RenameHoleFS($NEWActiveFS)
FUNCTION RenameHoleFS(STRING CWP) {
// Renames Featureset to add non-chamger diameter
	STRING WPN = workplane.name
	STRING MessageString = ""
	STRING TempString = ""
	INT FIndex = 0
	INT StringStart = LENGTH($WPN) + 1
	INT StringEnd = POSITION($CWP,"_NO_CHAMFERS")
	INT StringLen = $StringEnd - $StringStart
	$TempString = SUBSTRING($CWP, $StringStart, $StringLen)
	PRINT $TempString
	REAL FirstDia = REAL($TempString)
	PRINT $FirstDia
	REAL NewDia = 0
	//FIND OLD DIAMETER
	FOREACH f IN COMPONENTS(ENTITY('featureset',$CWP)) {
		$FIndex = $FIndex + 1
		IF f.type == "hole" {
			//$MessageString = "New Hole DIAMETER: "+STRING($f.DIAMETER)
			$NewDia = f.diameter
			//PRINT $MessageString
STRING TempName = "("+STRING($NewDia)+")_"+$TempString
STRING NewName = REPLACE($CWP, $TempString, $TempName)
RENAME Featureset $CWP $NewName
DELETE FEATURESET "1"
Thank to who help !
Replies (9)
Message 2 of 10
ondrej.mikulec
The ending on the line 151 and 152 needs to be moved into lines 27 and 28 so the main function block will be closed before the other sub-functions codes.
Message 3 of 10
icse
i added the missing {
also the last command (delete featureset "1") looks like out of place
FUNCTION Main () {
	FORM BLOCK
	EDIT BLOCK RESET
	BLOCK ACCEPT
	INT subNum = 0
	INT comp = 0
	STRING $Testing = 0
	INT SSubIndex = 0
			$SSubIndex = 0
						IF $SSubIndex < 2 {
							$RemovedChamfer = 1
							IF subNum > 0 {
								REAL depth = 0
								} ELSE {
				$subNum = 0
		$comp = $comp + 1
		PRINT $Testing
	$comp = 0
	INT FIndex = 0
	PRINT $TempString
	PRINT $FirstDia
	REAL NewDia = 0
	//FIND OLD DIAMETER
Message 4 of 10
karan30782
Thanks my friend.
Message 5 of 10
karan30782
Hi !
But, My issue isn't resolved.
This macro create hole with chamfer only, but it was intended to eleminate all chemfers.
It created hole with chemfer like this....
I need like this
Thank you !!
Message 6 of 10
karan30782
Hi !
Message 7 of 10
huseyin_sahin
I use  attached macro to delete chamfers from holes.
Message 8 of 10
karan30782
not working
Message 9 of 10
huseyin_sahin
Working at my side.
Message 10 of 10
karan30782
That's nice ..
Let me try once again.
Will let you know if works !
Thanks again
