Macro to change tool numbers in NC Program
E-Singer89
Message 1 of 10
E-Singer89
Hey all, so I was wondering if there is a way to write a macro to change tool numbers in an NC Program. The reason I ask is because; all of our 3-axis machines allow up to like 500 tools in the offset page whereas our 5-axis machines only allow up to like 200 (Haas). So, when programming and a job starts in 3-axis and ends in 5-axis, when I go to post out a 5-axis program I have to go into the NC program and manually change all the tool numbers, so we don't get an alarm on the machine. I would rather not have multiple tool libraries or multiple entries in the tool library to accommodate for this. Is there a way to write a macro that would change these tool numbers in the NC Program for me when I'm ready to post? I'm aware i would have to build the list in its entirety into the macro but that's fine. I'm just very unsure of how to phrase all the if-then statements (If that's what I would even use)
Replies (9)
Message 2 of 10
nguyenthinhvt95
Could you share some picture in detail?
Maybe somebody can help you.
Message 3 of 10
icse
This macro takes every tool in the project with a number larger than 200 and replaces its number with the first free lowest tool number:
int $newToolNumb = 0
foreach $t in filter(folder('tool'),'this.Number.Value > 200') {
	$newToolNumb = $newToolNumb + 1
	int list $toolnumbers = extract(folder('tool'), 'Tool.Number.Value')
	while member($toolnumbers, $newToolNumb) {
	EDIT TOOL ${t.Name} NUMBER COMMANDFROMUI ${newToolNumb}
Message 4 of 10
E-Singer89
Interesting, thank you. But not quite what I need. We have a set tool list of what tool is assigned to what offset number
Message 5 of 10
E-Singer89
sorry about that.
here is an example of a 3-axis program
5-axis program before settings change
this is where i change my tool numbers in the nc program
and this is what it looks like after the change, the asterisk notes that a change was made.
Message 6 of 10
icse
you coud make a .txt file for mapping
500|200
400|1
so number 500 is changed to 200, 400 is changed to 1 and so on
sry i misunderstood you i rewrite the macro
Message 7 of 10
E-Singer89
this is what i had in mind for sure. Is this going to change the tool numbers in the project though or just in the nc program? see my pictures above
Message 8 of 10
icse
Try this:
string $mappingPath = "C:\YourPath\mapping.txt"
if not file_exists($mappingPath) {
	message info "Can't find mapping file"
	return
string list $mapping = {}
FILE OPEN $mappingPath FOR READ AS Input
FILE READ $mapping FROM Input
FILE CLOSE Input
entity list $ncPrograms = input entity multiple ncprogram "Select NcPrograms to change tool numbers"
foreach $ncprogram in $ncPrograms {
	foreach $line in $mapping {
		int $target = tokens($line,'|')[0]
		int $dest = tokens($line,'|')[1]
		foreach $tp in filter(components($ncprogram),'this.ToolNumber.FromTool == "' + $target + '"') {
			$tp.ToolNumber.UserDefined = 1
			$tp.ToolNumber.Typed = $dest
			$tp.ToolNumber.Value = $dest
but please make a backup of your project first i did not tested it jet...
Message 9 of 10
E-Singer89
I will test this on a dummy file. Thank you! ill let you know how it goes
Message 10 of 10
E-Singer89
it works!!!! thank you!!!!
