Macro command to open html file using Microsoft Word
iamcdn79
Mentor Mentor
Message 1 of 42
iamcdn79
I just posted this 2 mins ago and it got deleted by someone in the forum page, so sorry if its not as detailed cause I am furious right now about it getting deleted
I am trying to create a macro that opens HTML files using Microsoft Word but get an error saying no program appears to be associated...
Does anyone know the right command to open HTML files?
FUNCTION Main (STRING $Selected_NCProgram)
    // Execute preliminary commands
    KEEP SETUPSHEETS NCPROGRAM SELECTED
    TEXTINFO ACCEPT
    SPLITTER TABEXPLORE
    // Get the main project directory and construct the correct path
    STRING mainDirectory = dirname(project_pathname(0), "/")
    STRING projectSubfolder = project.Name + ""
    STRING htmlFilePath = mainDirectory + "/" + projectSubfolder + "/SetupSheets_files/project_sheets/lineup sheet.html"
    // Attempt to open the specified .html file in the correct directory
    OLE FILEACTION 'open' $htmlFilePath
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
Replies (41)
Message 21 of 42
rafael.sansao
On my computer, everything works as expected, so I believe there may be a group policy restriction on your system.
Let’s try the following steps:
- Comment out this line: //DELETE FILE $ps1_path
- Run the macro.
- Open the Word file manually.
- In the project directory, locate the file named run.ps1, right-click it, and select "Run with PowerShell".
This should close the Word file. If it doesn’t, edit the "run.ps1" file and add this line at the end:
Pause
Then, run the file again by right-clicking and selecting "Run with PowerShell".
Please send me a screenshot of the PowerShell window if you encounter any issues.
Rafael Sansão
OptiNC - www.optinc.tech
Message 22 of 42
iamcdn79
When I add the pause in the ps1 file and run it, it doesn't pause, a window quickly opens and closes so I can't see what it says. I had to use a screen recorder then pause it and take a screenshot
this is where I add the pause in the ps1 file
this is the screen shot of the ps1 being ran manually
 but it still doesn't close the Word automatically
Windows 11 Pro
Message 23 of 42
rafael.sansao
Try this:
    // Get the main project directory and construct the exact path
    STRING $mainDirectory = REPLACE(project_pathname(0), "/", "\")
    STRING $htmlFilePath = $mainDirectory + "\SetupSheets_files\project_sheets\lineup sheet.html"
    IF ($powermill.Status.MultipleSelection.First) OR ($powermill.Status.MultipleSelection.Total == 0) {
		IF file_exists($htmlFilePath) {
			STRING $char = "$"
			STRING $ps1_content = $char + 'path = "' + $htmlFilePath + '"'
			$ps1_content = $ps1_content + CRLF + $char + 'word = [Runtime.InteropServices.Marshal]::GetActiveObject("Word.Application")'
			$ps1_content = $ps1_content + CRLF + 'foreach (' + $char + 'doc in ' + $char + 'word.Documents) {'
			$ps1_content = $ps1_content + CRLF + '    if (' + $char + 'doc.FullName -eq ' + $char + 'path) {'
			$ps1_content = $ps1_content + CRLF + '        ' + $char + 'doc.Close(0)'
			$ps1_content = $ps1_content + CRLF + '        break'
			$ps1_content = $ps1_content + CRLF + '    }'
			$ps1_content = $ps1_content + CRLF + '}'
			STRING $ps1_path = "C:\temp\run.ps1"
			FILE OPEN $ps1_path FOR WRITE AS cmd
			FILE WRITE $ps1_content TO cmd
			FILE CLOSE cmd
			OLE FILEACTION 'open' $ps1_path
			STRING $cmd_content = "@echo off" + CRLF + 'powershell -ExecutionPolicy Bypass -File "' + $ps1_path + '"'
			STRING $cmd_path = "C:\temp\run.cmd"
			FILE OPEN $cmd_path FOR WRITE AS cmd
			FILE WRITE $cmd_content TO cmd
			FILE CLOSE cmd
			OLE FILEACTION 'open' $cmd_path
			WAIT 2
			DELETE FILE $cmd_path
		TEXTINFO ACCEPT
		SPLITTER TABEXPLORE
    IF NOT file_exists($htmlFilePath) {
		MESSAGE WARN "File not exists"
		MACRO ABORT
	} ELSE {
		STRING $cmd_content = "@echo off" + CRLF + 'start "" "' + $htmlFilePath + '"'
		STRING $cmd_path = $mainDirectory + "\run.cmd"
		FILE CLOSE cmd
         //Check if it is the last selection or if there are no items selected
        IF ($powermill.Status.MultipleSelection.Last) OR ($powermill.Status.MultipleSelection.Total == 0) {
            WAIT 1
Rafael Sansão
Message 24 of 42
iamcdn79
Still the same thing. Do I have the right scripts enabled in the group policy?
Windows 11 Pro
Message 25 of 42
rafael.sansao
- Run Powershell as administrator
- Type: Set-ExecutionPolicy Unrestricted
- Click enter
- Type Y , click enter
Rafael Sansão
Message 26 of 42
iamcdn79
Is the red suppose to give this msg?
Windows 11 Pro
Message 27 of 42
rafael.sansao
It shouldn't.
Type: Get-ExecutionPolicy -List
And show me the image
Rafael Sansão
Message 28 of 42
iamcdn79
Windows 11 Pro
Message 29 of 42
rafael.sansao
The error you're receiving indicates that the execution policy was successfully updated, but it's being overridden by a policy defined at a more specific scope. This means a policy set at a higher level (such as in Group Policy or at the `LocalMachine` level) is taking precedence.
To investigate and fix this, follow these steps:
### 1. Check the execution policies at all scopes:
Run the following command to list all the execution policy settings for different scopes:
```powershell
This will display something like:
Scope ExecutionPolicy
MachinePolicy AllSigned
UserPolicy AllSigned
Process Undefined
CurrentUser RemoteSigned
LocalMachine RemoteSigned
### 2. Identify where the override is happening:
- If **MachinePolicy** or **UserPolicy** is set to `AllSigned`, this indicates that a Group Policy is enforcing that setting.
### 3. How to resolve:
#### If you're an administrator:
- To fix this, you will need to change the Group Policy setting that is enforcing the execution policy. If a Group Policy is set to `AllSigned` or another policy, it will take precedence.
To modify Group Policy settings:
1. Open the **Local Group Policy Editor** (`gpedit.msc`).
2. Navigate to:
Computer Configuration > Administrative Templates > Windows Components > Windows PowerShell
3. Check the settings for the policy **"Allow all Windows PowerShell scripts to run"**. If needed, adjust it to allow script execution.
#### If you're not an administrator or don't want to modify Group Policy:
- Unfortunately, the Group Policy set at a higher level cannot be overridden by user-level settings unless you have administrator permissions to modify the policy.
If adjusting the execution policy is necessary, you may need to request the administrator to modify the GPO settings or use the `Set-ExecutionPolicy` command with administrative privileges.
Rafael Sansão
Message 30 of 42
iamcdn79
2. Navigate to:
I don't have this option
Windows 11 Pro
Message 31 of 42
iamcdn79
does it maybe mean for this when right-clicking "Turn on Script Execution"?
Windows 11 Pro
Message 32 of 42
rafael.sansao
Apparently so. You have to try it!
Rafael Sansão
Message 33 of 42
iamcdn79
That was the problem, changing it to "allow all scripts" from "allow only signed scripts" macro code works now.
Now, does this make me more susceptible to viruses, malware, hacker attacks by enabling this powershell script?
Windows 11 Pro
Message 34 of 42
iamcdn79
I changed the setting to "Allow local scripts and remote signed scripts" which gives me a better level of security than "Allow All" and the code still runs correctly
Windows 11 Pro
Message 35 of 42
iamcdn79
Thanks for all your help Rafael, appreciate it.
Windows 11 Pro
Message 36 of 42
rafael.sansao
You're welcome, we're here to help each other.
Rafael Sansão
Message 37 of 42
realestatejot
Community Visitor
Community Visitor
To open an HTML file using Microsoft Word via a macro, you can use the following VBA (Visual Basic for Applications) command. First, open Microsoft Word and press Alt + F11 to open the VBA editor. Then, insert a new module and paste this code:
Save and run the macro to open the specified HTML file in Microsoft Word. This method allows easy integration of HTML files within Word documents for editing or formatting.
Message 38 of 42
iamcdn79
@rafael.sansao this code no longer works as intended anymore, either a Windows 11 update or a Microsoft Office update broke it. 😠😠
The only way I can get it to work partialy now as intended is to add a MESSAGE INFO dialog popup at the end of the code but the problem with that is now I always have to click on it to close. I don't believe there is a command to add that will close the popup automatically.
Also if the file already exists it will not overwrite and open it like it did previously.
This is the code that only works partially if adding the MESSAGE INFO and if the file doesn't exist, if it exists this will not open it, i have to delete the file muanally :
			STRING $char = "$"
			FILE CLOSE cmd
			FILE CLOSE cmd
			WAIT 2
		TEXTINFO ACCEPT
		SPLITTER TABEXPLORE
		MACRO ABORT
	} ELSE {
		FILE CLOSE cmd
            WAIT 1
            //I HAVE TO ADD THIS MESSAGE INFO LINE FOR IT TO WORK PARTIALLY AS EXPECTED NOW
            MESSAGE INFO "Waited 1 second for Word file."
Windows 11 Pro
Message 39 of 42
artur.boszczyk
why cannot you just simply pack this command
"C:\Program Files (x86)\Microsoft Office\root\Office16\WINWORD.EXE" /t "C:\AWB\3732-2008A_wingpin_v2.html"
into .bat file and execute it using
OLE FILEACTION 'open' "C:\AWB\open.bat"
Message 40 of 42
iamcdn79
That had no effect.
I got it to work using VB Script now
FUNCTION Main()
    // --- Close Word if the file is open ---
            STRING $vbsCloseContent = 'On Error Resume Next' + CRLF
            $vbsCloseContent = $vbsCloseContent + 'Set wordApp = GetObject(, "Word.Application")' + CRLF
            $vbsCloseContent = $vbsCloseContent + 'For Each doc In wordApp.Documents' + CRLF
            $vbsCloseContent = $vbsCloseContent + '    If doc.FullName = "' + $htmlFilePath + '" Then doc.Close False' + CRLF
            $vbsCloseContent = $vbsCloseContent + 'Next' + CRLF
            $vbsCloseContent = $vbsCloseContent + 'wordApp.Quit' + CRLF
            STRING $vbsClosePath = $mainDirectory + "\close_lineup.vbs"
            FILE OPEN $vbsClosePath FOR WRITE AS cmd
            FILE WRITE $vbsCloseContent TO cmd
            FILE CLOSE cmd
            OLE FILEACTION 'open' $vbsClosePath
            WAIT 1
            DELETE FILE $vbsClosePath
    // --- Check file exists ---
        MESSAGE WARN "File Does Not Exist"
        MACRO ABORT
    // --- Overwrite / regenerate HTML ---
        TEXTINFO ACCEPT
        SPLITTER TABEXPLORE
    // --- Open the newly written HTML file in the foreground ---
        STRING $vbsOpenContent = 'Set shell = CreateObject("WScript.Shell")' + CRLF
        $vbsOpenContent = $vbsOpenContent + 'shell.Run "winword.exe ""' + $htmlFilePath + '""", 1, False' + CRLF
        STRING $vbsOpenPath = $mainDirectory + "\open_lineup.vbs"
        FILE OPEN $vbsOpenPath FOR WRITE AS cmd
        FILE WRITE $vbsOpenContent TO cmd
        FILE CLOSE cmd
        OLE FILEACTION 'open' $vbsOpenPath
        WAIT 1
        DELETE FILE $vbsOpenPath
Windows 11 Pro
