How to use 3D offset finishing on multi axis with multiple surfaces ?
hamed.desighn
Message 1 of 8
hamed.desighn
Hi , im using this model right here with the boundary as you can see using "3D offset finishing" toolpath but it seems like powermill somehow reads boundary as  a two dimensional curve rather than a 3d boundary , im so confused right now .
Replies (7)
Message 2 of 8
jianhua.fan
Is this because the model has undercut if you view from +z-axis, and the offset finishing strategy cannot machine it?
Jianhua Fan
Message 3 of 8
hamed.desighn
exactly , if i see the model from z+ axis the boundary looks working in that way , one alternative approach was to rotate the workplane around X axis to math tha z axis with boundary definition but it didn't gave me accurate result also needs extra work , i didn't get under cut meaning tho is that means the model is unsewed or open ? cause the model is solid and no gaps in it .
Message 4 of 8
jianhua.fan
undercut means part of model is hidden by other part and cannot be seen if you view from the top.
Jianhua Fan
Message 5 of 8
hamed.desighn
What would i do then ? any help appreciated
Message 6 of 8
hamed.desighn
Jesus christ someone please help 😥🙏
Message 7 of 8
M_Hennig
 3d offset finishing only projects the way the work plane is orientated,  try surface projection finishing or alter your work plane so there are no undercuts.
Message 8 of 8
SupportEmail
Observer
Observer
You could also use a line projection toolpath and trim back what you don't need.
