how to make continious finishing tool path using 5 axis
malinsAM3TM
malinsAM3TM
We have a requirement to finish job with minimum time
iamcdn79
Have a look at this post for tips and specifically at @jonathan.artiss video tutorial
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
TK.421
Use a swarf toolpath with step downs. it'll give you a better finish than using the bottom of the cutter.  If you must cut it that way, use the surface finishing strategy with the toolaxis set to lead/lean and contact normal. in both cases, you will need to select the surface for calculation
the numbers never lie
kukelyk
Try Constant-Z with fix 7° elevation
