How to adjust post processor for getting G codes ijk (spiral) in constant Z
Message 1 of 20
Greeting,
Dear Madam/ Sir
Around more than 5 years, I am grappling with receiving ijk G codes associated with spiral in constant Z strategy.
For this purpose, I have done some researches as well as surfed the net to find how can I getting ijk G codes when I use the constant Z strategy in POWER MILL software.
So I was extremely wondering if you would mind guiding me if how can I receive G2 G3 codes when I use the constant Z in Spiral mode.
Best regards,
Mohammad Asalpisheh
Replies (19)
Message 2 of 20
powercam.ir
[video]
Message 3 of 20
M_Hennig
I have been down this road in the past, it's my understanding that you cannot get arc output unless the movements are in a principal plane. In other words, no spiral movements or 5x moves.
Message 4 of 20
CDN_Machinist_351Windsor
what post are you using on what controller?
Message 5 of 20
I have used FANUC post processor
Message 6 of 20
Many thanks for your info,
I have done all details based on related info mentioned in post, but I could not receive all statement in ijk g codes,
So could you please give me further details?
Message 7 of 20
yes! that is correct, would you please let me know if how can I solve my current problem?
Message 8 of 20
rafael.sansao
Very good video.
Additionally, to reduce the number of toolpath segments, set up the point distribution:
Rafael Sansão
OptiNC - www.optinc.tech
Message 9 of 20
Many thanks!
Message 10 of 20
it was related to FANUC post processor
Message 11 of 20
I also try this but this technique did not work with spiral in constant z ...
any one can help me ... ?
and also can any one tell me how to generate codes in the form of I J K with optimized constant z Finishing strategies ..
Message 12 of 20
As M.Hennig noted earlier, you cannot get arc output unless the movements are in a principal plane.
Exception, if your CNC-controller support arbitary plane arcs (like Sinumeric 840D), this option is configured in PostProcessor.
So, the only way out is to configure the point distribution for smooth machine movements.
Message 13 of 20
yes
Message 14 of 20
Meysam_Ghorbani
Message 15 of 20
Thanks for your reply its very helpful but from where we can get this fanuc helical file.
waiting for your reply
thanks
Message 16 of 20
powercam.ir
hi. this for you
Message 17 of 20
I have same problem , in powermill 2020 i can get helical output arcs with constant z but when the tolerance is below .05mm or the step down value increases near  0.4  , the output is linearized.whats the problem ?!
Message 18 of 20
faizbhatti840
Observer
Observer
Hay
I am Faiz
Can you help me how can to output NC with i,j,k Value in spiral mode
Message 19 of 20
amin13751387
send me your sample file. I can probabely help you. hr_hadizadeh@yahoo.com
Message 20 of 20
what machine are u posting to i will fix your post if you let me know what
it is
