Feature set folder name
peterquRXR7S
peterquRXR7S
I want to activate the folder(Waterline). But I can not get its name. How do I activate it?
Replies (7)
rafael.sansao
IF entity_exists($entity("Featureset","")) {
	ACTIVATE FOLDER ${dirname(pathname($entity("Featureset","")))}
Rafael Sansão
OptiNC - www.optinc.tech
peterquRXR7S
Thank you. No error. But it doesn't work properly. I print it out and the path is not what I want. See the picture below.
string $p=dirname(pathname($entity("Featureset","")))
print $p
peterquRXR7S
I tried this,
string $p=pathname($entity("Featureset",""))
print $p
and got "Featureset\FCS-24MM-DIA-M16-REG". Still not right.
rafael.sansao
The active hole feature set must be inside the folder. Looking at the image you uploaded, it is out of the folder.
Rafael Sansão
nguyenthinhvt95
Hi @peterquRXR7S
Here you go
DIALOGS MESSAGE OFF
DIALOGS ERROR OFF
STRING LIST folders = get_folders('FeatureSet')
INT idx = INPUT CHOICE folders "Pick a folder"
ACTIVATE FOLDER ${folders[idx]}
DIALOGS MESSAGE ON
DIALOGS ERROR ON
peterquRXR7S
Yes. You were right. The feature set is out of the folder. Thank you so much!
peterquRXR7S
It is good too. Thank you so much!
